Product
Brand
Zyxel NBG6716-EU0101F Simultaneous Dual-Band Wireless Router
Quicklinx: 8ZSVWS00 Mfr#: NBG6716-EU0101F
  • IEEE 802.11n
Cloud Media Stream, Cloud HD Boost
The ZyXEL NBG6716 Simultaneous Dual-Band Wireless AC1750 HD Media Router is designed for enabling smoother multimedia streaming through the latest AC technology. With StreamBoost™ support, the Smart QoS intelligently identifies, classifies and manages all the traffics on your home network to dynamically give each application the bandwidth and speed it requires for the best online experience.
Latest 802.11ac wireless technology 3 times faster than 802.11n
The ZyXEL NBG6716 provides high-throughput of up to 1300 Mbps*, 3 times the speed of 802.11n technology at the 5 GHz band. The NBG6716 can deliver high-quality full-HD video to multiple users throughout the house.
True dual-band radio optimized for High-quality HD media, gaming and Web browsing
The ZyXEL NBG6716 enables you to enjoy HD video streaming. Users can browse the Web on the 2.4 GHz band while watching HD video or play online games over the less-crowded 5 GHz band with smooth playback and low latency.
Specialized Smart QoS for the best movie, video and gaming experience
The ZyXEL NBG6716 adopts Smart QoS that takes advantage of the intelligent StreamBoost™ adaptive routing technology to bring unprecedented performance to home networks. It prioritizes bandwidth usages for optimized multi-stream HD video, gaming, IP voice services and Web browsing through assigning appropriate bandwidths to each application automatically. Smart QoS features an intelligent patent-pending algorithm that handles streams automatically to manage Internet traffic flows without user configuration; and it also minimizes the impact from large packets and lower-priority traffics on latency-sensitive tasks to effectively eliminate interruption to online games and video steaming applications.
  • The maximum wireless data transfer rates of up to 450 Mbps at 2.4 GHz and 1300 Mbps at 5 GHz in simultaneous transmission are derived from the IEEE Standard 802.11 specifications. Actual data transfer rates may vary from network conditions including: distance, network traffics, building site material/construction, interference from other wireless devices and other adverse factors.
Zyxel NBG6716 - wireless router - 802.11a/b/g/n/ac - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1300 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP, DDNS
Routing Protocol
IGMPv2, IGMP
Firewall protection, NAT support, auto-uplink (auto MDI/MDI-X), DoS attack prevention, MAC address filtering, VPN passthrough, Access Point operational mode, firmware upgradable, Wi-Fi Multimedia (WMM) support, Auto Channel Select (ACS), Quality of Service (QoS), Wi-Fi Protected Setup (WPS), reset button, bandwidth control, NetUSB support, StreamBoost
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, DLNA CERTIFIED, UPnP, IEEE 802.11ac
21.4 cm x 7.4 cm x 16.5 cm
460 g
Europe
2 years warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1300 Mbps
Routing Protocol
IGMPv2, IGMP
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, DLNA CERTIFIED, UPnP, IEEE 802.11ac, EMC, FCC, LVD
Status Indicators
Power, WAN, LAN, wireless, USB, WPS
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB: 2 x 4 pin USB Type A
Aerial
Aerial
Internal
External power adapter
20.5 Watt
1 x network cable
Europe
21.4 cm
7.4 cm
16.5 cm
460 g
10 - 90% (non-condensing)
8ZSV C2G 2m USB 2.0 A/B Cable - Black In Stock £3.07
8ZSV C2G 5m USB 2.0 A/B Cable - Black In Stock £4.36
8ZSV C2G 2-Port USB 2.0 Manual Switch In Stock £17.17
8ZSV C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.00
8ZSV C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.75
8ZSV C2G 12m USB 2.0 A/A Active Extension Cable In Stock £15.46
