Zyxel NBG6616-EU0101F S-Dual-Band Wireless AC1200 Media Router
Quicklinx: 9Q8YWS00 Mfr#: NBG6616-EU0101F
Ultra-Fast Gigabit Router for Effortless HD Media Streaming
The ZyXEL NBG6616 Simultaneous Dual-Band Wireless AC1200 Media Router uses the latest AC technology to deliver concurrent transfer rates of up to 300 Mbps* for 2.4 GHz and 867 Mbps* for 5 GHz. The dual-band network allows home users to enjoy an enhanced streaming and file-sharing experience with wider coverage and faster transfer speeds.
Concurrent Dual-Band
Dual-band Wireless AC1200 Media Router with speeds up to 300+867 Mbps
Today's high-speed mobile media devices demand more from wireless network hardware. The ZyXEL NBG6616 supports high-performance wireless networking of up to 1200 Mbps* when connecting to mobile devices supporting both 802.11n and 802.11ac for media streaming. The NBG6616 delivers high-quality full-HD video to multiple users over the less-crowded 5 GHz band for smooth playback with low latency.
Parental Control
Easy management with parental control and domain blocking
Easily set up and manage your home network devices with the ZyXEL NBG6616. You can control the bandwidth, restrict individual devices's Web access and parents can schedule the times at which Internet browsing is permitted on individual devices.
Qos for Prioritized Application
Advanced Quality of Service (QoS) ensures smooth multimedia streaming
Nobody likes having their media experience interrupted by choppy streaming. The ZyXEL NBG6616 QoS feature avoids this by prioritizing bandwidth usage to optimize multi-stream HD video, gaming, IP voice services and Web browsing. It improves the flow of critical network traffic--particularly useful with devices like VoIP phones or when used on high-volume networks.
  • The maximum wireless data transfer rate is derived from IEEE Standard 802.11 specifications. Actual data transfer rate will vary from network environment including: distance, network traffic, building site materials/construction, interference from other wireless devices, and other adverse conditions. This product compliant 802.11ac with wireless speeds of up to 1200Mbps.
  • Dual-band wireless AC1200 media router
    Today's high-speed mobile media devices demand more from wireless network hardware. The ZyXEL NBG6616 supports high-performance wireless networking when connecting to mobile devices supporting both 802.11n and 802.11ac for media streaming. The NBG6616 delivers high-quality full-HD video to multiple users over the less-crowded 5 GHz band for smooth playback with low latency.
  • Easy management with parental control and domain blocking
  • Advanced Quality of Service (QoS) ensures smooth multimedia streaming
    Nobody likes having their media experience interrupted by choppy streaming. The ZyXEL NBG6616 QoS feature avoids this by prioritizing bandwidth usage to optimize multi-stream HD video, gaming, IP voice services and Web browsing. It improves the flow of critical network traffic - particularly useful with devices like VoIP phones or when used on high-volume networks.
Zyxel NBG6616 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
867 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP, DDNS
Routing Protocol
IGMPv2, IGMP, static IP routing
Remote Management Protocol
Telnet, HTTP
NAT support, auto-uplink (auto MDI/MDI-X), MAC address filtering, VPN passthrough, firmware upgradable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, reset button, DLNA Media Server, on/off switches, DHCP client, Denial of Service (DoS)
18 cm x 12 cm x 3 cm
375 g
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
867 Mbps
Routing Protocol
Telnet, HTTP
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, BSMI, EMC, FCC, LVD
Status Indicators
Power, WLAN, WAN, LAN, USB, WPS
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A
Aerial
Aerial
External integrated
Antenna Qty
2
External power adapter
24 Watt
1 x network cable
18 cm
12 cm
3 cm
375 g
10 - 90% (non-condensing)
