Product
Zyxel NBG-418Nv2 Wireless N300 Home Router
Quicklinx: 9NR2WS00 Mfr#: NBG-418NV2-BG0101F
  • IEEE 802.11n
Delivering wireless connectivity at speeds of up to 300 Mbps* with the 802.11n technology, the ZyXEL NBG-418N v2 Wireless N300 Home Router is a wide-coverage wireless solution ideal for homes. The NBG-418N v2 provides stable, reliable wireless connectivity for Web browsing, file exchange, media streaming and online gaming.
Benefits
Compliant with 802.11n with data transfer rates of up to 300 Mbps* With wireless speeds of up to 300 Mbps* thanks to the 802.11n technology, the ZyXEL NBG-418N v2 features bandwidth management that enables you to prioritize network traffics, making it ideal for streaming, online gaming and Web browsing throughout your home.
Two omni 5 dBi antennas for stable data transmission and wider coverage
With two omni 5 dBi antennas, the ZyXEL NBG-418N v2 provides a wider wireless range for you to enjoy wireless services throughout the home network and even in your backyard. You'll enjoy stable, reliable wireless connections for Web browsing, file exchange and multimedia streaming everywhere at home.
Wi-Fi Protected Setup (WPS) for quick, easy wireless security setup
The ZyXEL NBG-418N v2 features WPS that allows users to quickly establish network security simply by pressing the WPS button on the router.
Support for IPv6
The accelerated growth of Internet causes the limited IPv4 addresses to deplete shortly. As a result, many sites are now moving to IPv6 addresses; and the ZyXEL's NBG-418N v2 is the perfect choice for Web browsing today and in the future for its IPv6-readiness.
Online firmware upgrade service for feature enhancements
With just a click, you can upgrade the ZyXEL NBG-418N v2's firmware when updates or enhancements become available.
Eco-friendly router saves energy
The ZyXEL NBG-418N v2 features wireless scheduling and it can be configured to enable/disable wireless services according to your network usage needs. In addition, you can use the power on/off button on the rear panel to toggle wireless connectivity in a snap.
  • Better wireless experience
    Compliant with 802.11n technology, the ZyXEL NBG-418N Wireless N home router can upgrade home networks with faster wireless speeds of up to 300 Mbps to provide more stable and reliable wireless connections for Web surfing and multimedia streaming. With Wi-Fi Multimedia (WMM) technology, the NBG-418N enhances your audio, video and voice application experience over wireless networks through the capability to prioritize different network traffic types for optimized performance.
  • Secured wireless environments
    With the Wi-Fi Protected Setup (WPS) push button, establishing a secure wireless network can't be easier. The WPS takes only a few seconds to set up a secure wireless network without any complicated procedure; and 64/128-bit WEP and WPA-PSK/WPA2-PSK are also supported to provide stringent protection for wireless transmissions.
  • Saves energy in smart ways
    Featuring a power-saving mode, the NBG-418N can automatically reduce wasted energy when there is no transmission traffic. In addition, the NBG-418N can also detect the length of connected Ethernet cables and then adjust power usage accordingly. The shorter the Ethernet cable length, the less power it consumes.
Zyxel NBG-418N - v2 - wireless router - 802.11b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Data Transfer Rate
300 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP
Routing Protocol
Static IP routing
Firewall protection, NAT support, auto-uplink (auto MDI/MDI-X), repeating mode, DoS attack prevention, dynamic DNS server, MAC address filtering, IPv6 support, Access Point operational mode, firmware upgradable, Wi-Fi Multimedia (WMM) support, Auto Channel Select (ACS), Wi-Fi Protected Setup (WPS), DHCP server, reset button, bandwidth control, DHCP client
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, UPnP
14.2 cm x 10.2 cm x 2.3 cm
148 g
United Kingdom
Enclosure Type
Desktop
Wireless, wired
Data Transfer Rate
300 Mbps
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, UPnP, BSMI, FCC, RoHS, LVD
Status Indicators
Power, WLAN, WAN, WPS
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
External integrated
Antenna Qty
2
Directivity
Omni-directional
Gain Level
5 dBi
External power adapter
3.5 Watt
1 x network cable
United Kingdom
14.2 cm
10.2 cm
2.3 cm
148 g
10 - 90% (non-condensing)
