The MI-7526F is a Gigabit Ethernet interface module that has 20 mini-GBIC (SFP) slots and four dual personality interfaces. It also has one slot for a 10 Gigabit uplink module.
- Zyxel MI-7526F - expansion module - Gigabit Ethernet x 4
- Expansion module
- Form Factor
- Plug-in module
- Ports
- 39.7 cm x 27.6 cm x 4.3 cm
- 2.1 kg
- Auxiliary Ports
- 4 x shared Ethernet 1000Base-T
- Data Link Protocol
- GigE
- Data Transfer Rate
- 1 Gbps
- Expansion module
- Form Factor
- Plug-in module
- Ports
- Connectivity Technology
- Wired
- Gigabit Ethernet
- Auxiliary Ports
- 1 Gbps
- Status Indicators
- Power, active, status
- Expansion Slots
- 24 x SFP , 1 x expansion slot
- 4 x 1000Base-T - RJ-45
- Compatible Slots
- 1 x Expansion Slot
- CSA, EMC, FCC, UL 60950-1, IEC 60950-1, EN 60950-1
- 39.7 cm
- 27.6 cm
- 4.3 cm
- 2.1 kg
- 0 °C
- 45 °C
- 10 - 90%
