Product
Zyxel MGS-3712 12-port Gigabit L2 Metro Switch
Quicklinx: 8PFSWS00 Mfr#: 91-010-166024B
Type: Gigabit Ethernet
Ports: 8
Data Transfer Rate: 1Gbps
Managed: Yes
POE: No
£742.49 ex VAT
£890.98 inc VAT
The Metro Switch 3000 series is specially designed for service providers to deliver profitable Ethernet services. With the high-performance hardware platform, service providers can easily extend network topologies while enabling robust security, QoS and management functions to help customers fulfilling differentiated needs for Metro Ethernet service.
  • Meeting industry standards
    The Metro Ethernet Forum (MEF) is a global industry alliance comprised of more than 145 active members representing Carrier Ethernet industry groups. The forum develops technical specifications and implementation agreements to promote interoperability and deployment of Carrier Ethernet services worldwide. The Metro Switch 3000 series is aligned with carrier-class standards for Ethernet Private Line (EPL), Ethernet Virtual Private Line (EVPL) and Ethernet LAN (E-LAN) of Metro Ethernet Forum (MEF), and the Series has been certified as MEF-9 and MEF-14 compliant.
  • Advanced QoS for significant services
    Consistent service quality and reliable connecting ability in a converged network is the key for service providers to win customers and build loyalty; therefore the ability to control traffic flow and set traffic policy becomes more critical than ever. The Metro Switch 3000 Series offers wire-speed flow control that classifies and prioritizes the incoming packets according to the predefine QoS policies that meet requirements of service providers. In terms of classification, the Differentiated Services Code Point (DSCP) field and the 802.1p class of service (CoS) field are identified to assess the priority of incoming packets. Classification and reclassification can be based on criteria as specific as rules based on IP, MAC addresses, VLAN ID or TCP/UDP port number. For bandwidth management, the Metro Switch 3000 Series provides 8 priority queues per port for different types of traffics, allowing service providers to set rule-based rate limitations that take full advantage of constrained network resources and guarantee the best performance.
  • Enhanced security for protection among customers
    Avoiding subscribers affecting each other on a shared network or shared device is a major concern for service providers. The Metro Switch 3000 series offers a complete set of security features to protect user data while administrating the traffics. The intrusion lock function detects the "plugged" and "unplugged" status change of Ethernet cables, and the switch would deactivate a specific port automatically if needed, and the 802.1x authentication can secure the network from unauthorized users. Port security provides the ability to deny unauthorized users from accessing the network.
  • Resilient and redundant design
    A quick recovery and round-the-clock network is vital for service providers to establish a robust network. The Metro Switch 3000 series provides comprehensive features to make sure network is well operated. The IEEE 802.3ad Link Aggregation feature reduces network downtime by providing redundant paths and bandwidth aggregation to critical connections, while IEEE 802.1w Rapid Spanning Tree Protocol (RSTP) and IEEE 802.1s Multiple Spanning Tree Protocol (MSTP) allow immediate recovery from failed connections by sending packets via the backup link. Furthermore, since the Metro Switch 3000 series supports backup power system, the power is supplied to the switch in case of an unexpected outage.
  • Intelligent fan control algorithm for power saving
    Fans play an important role in energy consumption since it's the key to heat dissipation. The Metro Switch 3000 features auto temperature detection and appropriate fan speeds with the intelligent fan control algorithm based on complex mathematics and physics formulas. When the ambient temperature is low, the switch would decrease fan speed to prevent unnecessary power waste from excessive cooling.
  • Removable fan modules
    Removable fan modules provide flexibility and high availability, and they solve the noise problem when the modules are approaching the end of their life cycle. When necessary, customers can replace the fans with new ones by their own to save cost.
  • Optimized design for Metropolitan Area Network
    The Metro Switch 3000 series offers high operating temperature tolerance, flexible AC/DC dual-input power source as well as protection against humidity and dust for service providers to extend their networks. The Metro Switch 3000 series adopts the "front access" design for technicians to easily wire and maintain outdoor cabinets. The external alarm input/output block connects mechanical cabinet parts to the management network and offers better protection to the equipment.
  • Carrier switches supports DDMI (Digital Diagnostics Monitoring Interface) SFP
    The enhanced digital interface allows real-time access to device operating parameters, and includes optional digital features such as soft control and monitoring of SFP I/O signals. In addition, it fully incorporates the functionality needed to implement digital alarms and warnings.
Zyxel MGS-3712 - switch - 8 ports - Managed
Switch - 8 ports - Managed
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 + 4 x combo Gigabit SFP
Performance
Switching capacity: 24 Gbps , Forwarding performance: 17.8 Mpps
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c
ARP support, VLAN support, IGMP snooping, MAC address filtering, firmware upgradable, Weighted Fair Queuing (WFQ), DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), temperature / humidity sensor, DHCP relay, IP-MAC binding
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.3ah, IEEE 802.1ag
AC 120/230 V / DC -48 -60 V (50/60 Hz)
43.8 cm x 22.5 cm x 4.5 cm
3.4 kg
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9KB
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
8 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 4 x 1000Base-T - RJ-45 , 4 x SFP (mini-GBIC) , 1 x serial (RS-232) , 1 x console - RJ-45
Internal power supply
MTBF
320,302 hours
RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1
43.8 cm
22.5 cm
4.5 cm
3.4 kg
65 °C
10 - 99% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Ports: 8
Managed: Yes
POE: No
Brand: Zyxel
Price Range Ex VAT: 500 - 750
