Zyxel GS1900-48 Smart Managed 48 Port Switch
Quicklinx: BJ06WS00 Mfr#: GS1900-48-GB0101F
The ZyXEL GS1900 48-port GbE Smart Managed Switch with Gigabit speed and essential managing functions bring your business network more flexibility and connectivity. The GS1900-48HP is providing GbE switches with power saving functions, fanless design and full IPv6 support ensure your network to be ready for future expansions. In addition, the PoE models GS1900-48HP Gigabit switch complies with the IEEE 802.3at Power over Ethernet (PoE) Plus standard. The complete GS1900 has been designed with useful features and advanced performances that empower your networks with speed and security as well as silent operation in your office environments.
  • Versatility and fexibility for different needs
    The complete ZyXEL GS1900 48-port have compact desktop and rackmount size with GbE connectivity. All models support multiple deployment methods to fulfill the needs for small offices and meeting room environments such as wall-, under table- or desktop-mounting and rackmount options. It's now quick and e ffortless to enjoy the high-speed business network applications without a hitch. Additionally, the GS1900-48HP is equipped with 2 extra SFP slots to provide 100M and GbE speeds for long-distance deployments.
  • Simple, intuitive wizard set up
    For small businesses that want to manage their infrastructure in advance, the ZyXEL GS1900 Series comes with a friendly built-in Web-based browser for simple configuration and management. Moreover, the friendly step-by-step intuitive wizard helps avoiding multiple complicated configuration pages for quick set up with few clicks in the matter of minutes. To guide the users from start-up, VLAN, Guest VLAN to QoS setting, the ZyXEL Series off ers four most common steps and combines them into a quick and easy setup wizard; which does not just save deployment time and efforts, but is also helpful especially for the non-IT staff.
  • Avoiding network errors with easy management
    The ZyXEL GS1900 Series is equipped with advanced management features to make the network stable and secure - loop protection that prevents network flooding, dual images to provide a backup FW if one crashes and storm control to ensure network efficiency, friendly on/off DoS with simple click to enable/disable instead of several setup pages, while SSL ensures the management frames are well encrypted when the device is accessed. The GS1900 Series provides network error prevention features and integrated network security for reduced risk and improved data streaming.
  • Energy saving for IEEE 802.3az
    As operating overheads such as electric bills increase constantly due to the arising green awareness, businesses have to avoid unnecessary energy waste. The built-in IEEE 802.3az Energy Efficient Ethernet (EEE) and more ZyXEL innovative green features of ZyXEL GS1900 Series can reduce energy consumption of Ethernet devices through multiple intelligent ways.
Zyxel GS1900-48 - switch - 48 ports - smart - rack-mountable
Switch - 48 ports - smart
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 2 x Gigabit SFP
Performance
Switching capacity: 100 Gbps , Forwarding performance: 74 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3
Flow control, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DoS attack prevention, Weighted Round Robin (WRR) queuing, store and forward, IPv6 support, Quality of Service (QoS), fanless, LACP support, LLDP support, Port Security, Energy Efficient Ethernet, Management Information Base (MIB), Strict Priority Queuing (SPQ), Class of Service (CoS), tagged VLAN, per port bandwidth control, 1.5MB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1x, IEEE 802.1ab (LLDP), IEEE 802.3az
44 cm x 20 cm x 4.4 cm
2.9 kg
United Kingdom
Enclosure Type
Desktop, rack-mountable, wall-mountable
Subtype
Gigabit Ethernet
Ports
Performance
8K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+
Status Indicators
Power, system, link/activity
48 x 1000Base-T RJ-45 , 2 x SFP
Internal power supply
36.9 Watt
MTBF
229,313 hours
FCC Class B certified, RoHS, EN 60950-1, BSMI CNS 13438, C-Tick Class A, BSMI CNS 14336
United Kingdom
44 cm
20 cm
4.4 cm
2.9 kg
Limited warranty - lifetime
50 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
