Zyxel GS1100-16 16 port Gigabit Unmanaged Switch
Quicklinx: 95NBWS00 Mfr#: GS1100-16-GB0101F
The ZyXEL GS1100-16 is positioned to deliver a solution that requires no switch management for office environments demanding silent operation and green technology. It provides plug-and-play simplicity for high-bandwidth connectivity.
The GS1100-16 is a 16-port 10/100/1000 switch and protects your existing network investments while providing you with a straightforward migration path to faster Gigabit speeds.
  • IEEE Energy-Efficient-Ethernet (EEE) compliance
    The ZyXEL GS1100-16 offers environmental efficiency with Gigabit Ethernet speeds critical for next-generation network applications. To comply with the IEEE 802.3az standard, the GS1100-16 provides power saving functions to reduce energy consumption to help business save cost.
  • Fanless design
    Since the fanless design ensures quiet operation in small office spaces, the GS1100-16 is the perfect solution for small business and SOHO office deployments.
  • Gigabit to the desktop
    The GS1100-16 comprises of unmanaged Gigabit switches that provide an inexpensive desktop Gigabit solution for significant performance boost thanks to the higher network bandwidth. The GS1100-16 comes in desktop, wall-mountable or rack-mountable enclosure design is an ideal solution for bandwidth-intensive applications such as high-resolution photo transmission, video/audio streaming and downloading as well as server farm connections.
  • Power-packed delivery
    With the non-blocking switching architecture, the GS1100-16 filters and forwards packets at wire speed for maximum throughput. Features such as address learning and aging, 802.3x flow control adjust traffic congestion and ensure reliable data transmission. The GS1100-16 also supports jumbo frames of up to 9K bytes for extra large transfers.
  • Easy installation
    The GS1100-16 offers plug-and-play connectivity and easy installation. With the Auto-MDI/MDI-X feature, it eliminates the need for crossover cables when connecting to another switch or hub; the auto-negotiation feature senses the link speed of a network device and intelligently adjusts for compatibility and optimal performance.
Zyxel GS-1100-16 - switch - 16 ports
Switch - 16 ports
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Performance
Switching capacity: 32 Gbps , Forwarding performance: 23.8 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
9000 bytes
Flow control, auto-uplink (auto MDI/MDI-X), Broadcast Storm Control, fanless, Energy Efficient Ethernet, 256KB packet buffer, Class of Service (CoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
21.5 cm x 13.3 cm x 4.2 cm
1 kg
United Kingdom
Switch - 16 ports
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Performance
8K entries
Jumbo Frame Support
9000 bytes
16 x 1000Base-TX RJ-45
Internal power supply
6.4 Watt
MTBF
48,385 hours
RoHS, EN 60950-1, FCC Part 15 B Class A, EMC Class A
United Kingdom
21.5 cm
13.3 cm
4.2 cm
1 kg
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
