Zyxel GS108S 8-Port Desktop Gigabit Ethernet Media Switch
Quicklinx: 83XVWS00 Mfr#: GS-108S-GB0101F
Prioritize Multimedia Streams for Optimized Video and Online Gaming Enjoyments
The ZyXEL GS-108S 8-Port Desktop Gigabit Ethernet Media Switch can easily connect multiple media devices to home networks at blazing-fast Gigabit speed simultaneously. Moreover, the newly designed QoS ports of GS-108S allow smooth video streaming and online gaming as well.
Plug-and-play, stylish design
With easy plug-and-play, you can connect the GS-108S to media players, game consoles and smart TVs to your home network without any configuration effort. With its stylish modern look and streamlined design, the GS-108S fits nicely into any home décor.
Smooth multimedia streaming and gaming
The ZyXEL GS-108S features QoS ports for you to assign high, medium or low priorities for your preferred network applications. For instance, if you are a movie enthusiast, you can connect media players or smart TVs to the high-priority ports for smooth video streaming and the best home 3D streaming experience. If you prefer lag-free online gaming, simply connect the game console through the high-priority QoS port and assign media players, PC and other network devices to the medium- or low-priority QoS ports according to your need.
Blazing-fast Gigabit speed
The GS-108S 10/100/1000 Mbps switch is designed for reliable high-performance media networks 10 times faster than Fast Ethernet connections. It perfectly fulfills the demands for multimedia streaming and online gaming.
  • Enlarge Plug-and-Play, stylish design
    With easy Plug-and-Play, you can connect the GS-108S to media players, game consoles and smart TVs to your home network without any configuration effort. With its stylish modern look and streamlined design, the GS-108S fits nicely into any home decor.
  • Enlarge smooth multimedia streaming and gaming
  • Enlarge blazing-fast Gigabit speed
Zyxel GS-108S - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Non-blocking switching capacity: 16 Gbps
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, Quality of Service (QoS), Energy Efficient Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
AC 120/230 V
15.2 cm x 8 cm x 3.2 cm
150 g
United Kingdom
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
8K entries
Jumbo Frame Support
9KB
Status Indicators
Power, link/activity
2 x 1000Base-T RJ-45 high priority , 2 x 1000Base-T RJ-45 medium priority , 4 x 1000Base-T RJ-45 low priority
External power adapter
AC 120/230 V
4.5 Watt
Plug and Play, FCC Class B certified, C-Tick, BSMI, RoHS
United Kingdom
15.2 cm
8 cm
3.2 cm
150 g
10 - 90% (non-condensing)
