Zyxel Firewall Applinace 1xWAN, 1xSFP, 4xLAN/DMZ,  IEEE 802.11ac/n
Quicklinx: C1HTWS00 Mfr#: USG20W-VPN-EU0101F
£200.22 ex VAT
£240.26 inc VAT
The USG20W-VPN provides safe and reliable VPN connections. Faster processors have vastly boosted the capabilities of attackers to decrypt VPN tunnels. With support to the advanced Secure Hash Algorithm 2, the VPN firewall provides safe VPN connections to ensure maximum security for business communications.
  • Safer, more reliable VPN connections
  • Business mobility
    To support dynamic, mobile business operations in BYOD business environments, the VPN firewalls offer business mobility with Layer-2 Tunneling Protocol VPN for mobile devices. The VPN firewall supports L2TP VPN on a wide variety of mobile Internet devices.
Zyxel USG20W-VPN - firewall
Firewall
External
Europe
Frequency Band
2.4 GHz, 5 GHz
Performance
Firewall throughput: 350 Mbps , VPN throughput: 90 Mbps
User licences: unlimited , Concurrent IPSec VPN tunnels: 10 , Concurrent sessions: 20000 , Concurrent SSL VPN users: 1 , SSL VPN users: 5 , Maximum number of configured SSIDs: 8
VoIP Protocols
H.323, SIP
21.6 cm x 14.3 cm x 3.3 cm
1.04 kg
Firewall
21.6 cm
14.3 cm
3.3 cm
1.04 kg
Europe
External
Wired
Data Transfer Rate
1300 Mbps
Network / Transport Protocol
L2TP, IPSec, PPPoE, DNS, DDNS
Routing Protocol
OSPF, RIP-1, RIP-2, static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS
Frequency Band
2.4 GHz, 5 GHz
Performance
Routing, VPN support, PAT support, SNAT support, load balancing, VLAN support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, ALG support, manageable, stackable, E-mail alert, IPv6 support, High Availability, Transparency, firmware upgradable, DDos attack prevention, tunnelling, IPSec Virtual Private Network (VPN), Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), DHCP server, Multiple SSID support, bandwidth control, DHCP relay, CAPWAP support, DHCP client, dual firmware images, tagged VLAN, Captive Portal, Generic Routing Encapsulation (GRE), VPN auto-reconnection, Single Sign-On (SSO) support, ZyXEL One Network (ZON), SmartConnect Technology, Dynamic Channel Control, failover protection
Encryption Algorithm
DES, Triple DES, MD5, IKE, SSL, SHA-1, PKI, 256-bit AES, IKEv2, 512-bit SHA-2
Authentication Method
RADIUS, X.509 certificates, Radio Service Set ID (SSID), LDAP, XAUTH authentication
IEEE 802.1Q, IEEE 802.1x, X.509, IEEE 802.11n, IEEE 802.11ac
IP Telephony
VoIP Protocols
H.323, SIP
Aerial
Antenna
External detachable
Antenna Qty
3
Gain Level
3 dBi
4 x 1000Base-T - RJ-45 (LAN / DMZ) , 1 x 1000Base-T - RJ-45 (WAN) , 1 x USB - Type A , 1 x - SFP (mini-GBIC) , 1 x console - RJ-45
1 x console cable
MTBF
44,000 hour(s)
UL, BSMI, ICSA Firewall certified, FCC Part 15 B, IC, EMC Class B, RCM
External power adapter
12 Watt
10 - 90% (non-condensing)
C1HT C2G 2m USB 2.0 A/B Cable - Black In Stock £3.91
C1HT C2G 5m USB 2.0 A/B Cable - Black In Stock £5.10
C1HT C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.91
C1HT C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.94
C1HT C2G USB Superbooster Extender Kit In Stock £38.28
C1HT C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £23.67
C1HT C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
Brand: Zyxel
Price Range Ex VAT: 150 - 300
