Zyxel Firewall Applinace 1 x WAN, 1 x SFP, 4 x LAN/DMZ
Quicklinx: C1HSWS00 Mfr#: USG20-VPN-EU0101F
Hurry, only 2 left in stock!
£187.65 ex VAT
£225.18 inc VAT
The USG20-VPN provides safe and reliable VPN connections. Faster processors have vastly boosted the capabilities of attackers to decrypt VPN tunnels. With support to the advanced Secure Hash Algorithm 2, the VPN firewall provides safe VPN connections to ensure maximum security for business communications.
  • Safer, more reliable VPN connections
  • Business mobility
    To support dynamic, mobile business operations in BYOD business environments, the VPN firewalls offer business mobility with Layer-2 Tunneling Protocol VPN for mobile devices. The VPN firewall supports L2TP VPN on a wide variety of mobile Internet devices.
Zyxel USG20-VPN - firewall
Firewall
External
Europe
Performance
Firewall throughput: 350 Mbps , VPN throughput: 90 Mbps
User licences: unlimited , Concurrent IPSec VPN tunnels: 10 , Concurrent sessions: 20000 , Concurrent SSL VPN users: 1 , SSL VPN users: 5
VoIP Protocols
H.323, SIP
21.6 cm x 14.3 cm x 3.3 cm
1.04 kg
Firewall
21.6 cm
14.3 cm
3.3 cm
1.04 kg
Europe
External
Wired
Network / Transport Protocol
L2TP, IPSec, PPPoE, DNS, DDNS
Routing Protocol
OSPF, RIP-1, RIP-2, static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS
Performance
Routing, VPN support, PAT support, SNAT support, load balancing, VLAN support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, ALG support, manageable, stackable, E-mail alert, IPv6 support, High Availability, Transparency, firmware upgradable, DDos attack prevention, tunnelling, IPSec Virtual Private Network (VPN), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), DHCP server, bandwidth control, DHCP relay, DHCP client, dual firmware images, tagged VLAN, Generic Routing Encapsulation (GRE), VPN auto-reconnection, Single Sign-On (SSO) support, ZyXEL One Network (ZON), SmartConnect Technology, failover protection
Encryption Algorithm
DES, Triple DES, MD5, IKE, SSL, SHA-1, PKI, 256-bit AES, IKEv2, 512-bit SHA-2
Authentication Method
RADIUS, X.509 certificates, LDAP, XAUTH authentication
IEEE 802.1Q, X.509
IP Telephony
VoIP Protocols
H.323, SIP
4 x 1000Base-T - RJ-45 (LAN / DMZ) , 1 x 1000Base-T - RJ-45 (WAN) , 1 x USB - Type A , 1 x - SFP (mini-GBIC) , 1 x console - RJ-45
1 x console cable
MTBF
44,000 hour(s)
UL, BSMI, ICSA Firewall certified, FCC Part 15 B, IC, EMC Class B, RCM
External power adapter
12 Watt
10 - 90% (non-condensing)
Brand: Zyxel
Price Range Ex VAT: 150 - 300
