ZyXEL USG Extreme Series are Next Generation Firewalls (NGFW) designed to deliver high availability, anti-malware protection and consolidated policy enforcement for medium- and large-sized businesses and campuses. The ZyXEL USGs provide WAN and VPN load balancing and failover ensures nonstop business communications, while incorporating best-in-breed anti-virus, anti-spam, content filtering and application intelligence technology for effective application optimization and comprehensive network protection.
Powerful and robust
ZyXEL's USG Extreme Series is built on a powerful platform to deliver high performance that helps growing businesses to overcome challenges during the expansion. In order to satisfy the needs for always-online communications, the series features multi-WAN load balancing / failover and a comprehensive mobile broadband USB modem support list for WAN backup operations. In addition, the series supports IPSec load balancing and failover to provide additional resiliency for the most mission critical VPN deployments. -
Protection and optimization
The ZyXEL USG Extreme Series provides extensive anti-malware protection and effective control of web applications with firewall, anti-virus, anti-spam, content filtering, IDP and application intelligence. These security measures are enhanced with SSL inspection, which helps block threats that are hidden in SSL encrypted connections and facilitates deeper policy enforcement. -
Streamlined management
Unified security policy streamlines the configuration of firewall and every security feature to offer faster, easier and more consistent policy management. From a single interface, users can apply all policy criteria to every UTM feature with reduced complexity. The integrated WLAN controller also enables users to management up to 18 APs from a centralized user interface. -
Best TCO for Wi-Fi expansion
Addressing the connectivity needs in the BYOD trend, the ZyXEL USG Extreme Series helps businesses deploying or expanding a managed Wi-Fi network with minimized efforts. Integrated with ZyXEL AP Controller technology, the series enables businesses to easily scale up the WLAN and to provide seamless Wi-Fi coverage in places like meeting rooms and guest reception areas.
- Zyxel USG1900 - UTM Bundle - security appliance - with 1 year AV+IDP, AS, CF
- Security appliance
- Bundled Services
- 1 year AV+IDP, AS, CF
- Licence Qty
- 55 SSL VPN users
- Form Factor
- Rack-mountable
- Localisation
- United Kingdom
- Data Link Protocol
- Performance
- Firewall throughput: 7 Gbps , VPN throughput: 900 Mbps , Intrusion detection and prevention throughput: 650 Mbps , Antivirus throughput: 600 Mbps , Unified Threat Management (UTM) throughput: 600 Mbps
- Capacity
- User licences: unlimited , Concurrent IPSec VPN tunnels: 2000 , Concurrent sessions: 500000 , Concurrent SSL VPN users: 755 , Virtual interfaces (VLANs): 128 , New sessions: 12000 , Manageable access points: 2 (maximum 18)
- 43 cm x 25 cm x 4.4 cm
- 3.3 kg
- Bundled Services
- 43 cm
- 25 cm
- 4.4 cm
- 3.3 kg
- Localisation
- United Kingdom
- Form Factor
- Rack-mountable
- Connectivity Technology
- Wired
- L2TP, IPSec, PPPoE, SMTP, DHCP, POP3, IMAP4
- Routing Protocol
- OSPF, RIP-1, RIP-2, GRE
- Remote Management Protocol
- Telnet, SNMP 2c, HTTP, HTTPS, SSH
- Performance
- Capacity
- Status Indicators
- Port status, power, system
- Firewall protection, DMZ port, routing, DHCP support, NAT support, VPN support, PAT support, SNAT support, load balancing, LDAP support, VLAN support, Syslog support, DoS attack prevention, content filtering, ALG support, dynamic DNS server, manageable, stackable, E-mail alert, IPv6 support, antivirus analysis, High Availability, firmware upgradable, DDos attack prevention, tunnelling, IPSec Virtual Private Network (VPN), Wi-Fi Multimedia (WMM) support, anti-spam protection, Access Control List (ACL) support, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), SSH support, VPN failover, DHCP server, IPv4 support, 3G USB Dongle Support, DHCP relay, IP-MAC binding, CAPWAP support, DHCP client, dual firmware images, static routing, tagged VLAN, Captive Portal, Generic Routing Encapsulation (GRE), Intrusion Detection and Prevention (IDP), VPN concentrator, VPN load-balancing, VPN auto-reconnection, Single Sign-On (SSO) support
- Encryption Algorithm
- DES, Triple DES, MD5, IKE, SSL, SHA-1, PKI, 256-bit AES, IKEv2, 512-bit SHA-2
- Authentication Method
- Secure Shell (SSH), RADIUS, X.509 certificates, LDAP, Active Directory, Extensible Authentication Protocol (EAP), XAUTH authentication
- IEEE 802.1Q, X.509
- 8 x 1000Base-T - RJ-45 , 2 x USB - Type A , 1 x console - DB-9
- MTBF
- 560,811.5 hours
- BSMI, EN 60950-1, FCC Part 15 A, C-Tick Class A, LVD, EMC Class A
- Power Device
- External power adapter
- 58.5 Watt
- Virus definitions update - 1 year , Intrusion definitions update - 1 year , URL Database update - 1 year , Spam filter update - 1 year
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
