Zyxel EXT-114 14dBi Directional Outdoor Antenna
Quicklinx: BW60WS00 Mfr#: 91-005-049001B
Wireless network antennas typically perform best in open environments with the least amount of obstructions possible. Performance may be significantly impaired if antennas are mounted near metal surfaces, concrete walls, or other high-density materials. To meet the challenge of these and other severe environments, ZyXEL offers performance-enhancing antennas for its ZyAIR family of wireless modems.
ZyAIR's extended reach antennas allow users to get the best wireless performance out of the most difficult environments. With ZyAIR antennas, customers will enjoy greater reach and better transmission quality for their wireless networks.
Zyxel ZyAIR EXT 114 - antenna
Antenna
20 cm x 20 cm x 5 cm
Gain
14 dBi
Directivity
Directional
Antenna
20 cm
20 cm
5 cm
Aerial
Gain
14 dBi
Directivity
Directional
Cabling & Wiring
Connector Provided
1 x N-Series connector
-40 °C
70 °C
