Zyxel EM-412 10G Module for CX4 Connection incl. CX4 Cable
Quicklinx: BW49WS00 Mfr#: 91-010-195002B
The EM-412 is an uplink module with two slots for 10GBase-CX4. It works up to a distance of 15 meters (49 feet) with the advantage of having the lowest cost per port of all 10Gb interconnects. After installing the EM-412 in a switch, the switch can have 10 Gigabit connections to a backbone switch or other network devices.
Zyxel EM-412 - expansion module
Expansion module
Plug-in module
Ports
10GBase-CX4 x 2
8 cm x 16.8 cm x 2.8 cm
152 g
Cabling Type
Ethernet 10GBase-CX4
10 GigE
Data Transfer Rate
10 Gbps
IEEE 802.3ak
Expansion module
Plug-in module
Ports
10GBase-CX4 x 2
Wired
Cabling Type
10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
Status Indicators
Link/activity
Full duplex mode
IEEE 802.3ak
2 x 10GBase-CX4
1 x InfiniBand cable (external)
FCC Part 15 A
8 cm
16.8 cm
2.8 cm
152 g
45 °C
10 - 90% (non-condensing)
