To catch up the wave of 802.11n, the enterprise-level NWA3000-N series Access Point (AP) meets the requirement of the "n generation". The range provides various AP portfolios from single radio to concurrent radio, as well as dual-frequency APs. Designed to meet the requirements of SMB market segment, the NWA3000-N series is ideally suited for service delivery on mission-critical networks.
- Zyxel NWA-3160-N - radio access point
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Throughput: 120 Mbps
- Capacity
- Manageable access points: 24
- Power Over Ethernet (PoE) Supported
- PoE
- 19.8 cm x 13.8 cm x 4.5 cm
- 439 g
- 2 years warranty
- 19.8 cm
- 13.8 cm
- 4.5 cm
- 439 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Line Coding Format
- DQPSK, CCK, 64 QAM, QPSK, 16 QAM
- Remote Management Protocol
- SNMP 3, HTTP, SSH, CLI
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Capacity
- DHCP support, power over Ethernet (PoE), VLAN support, manageable, MAC address filtering, Wireless Distribution System (WDS) support, WLAN controller mode, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), rogue access point detection
- Encryption Algorithm
- SSL, TLS, PEAP, TTLS, WPA, WPA2, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
- Authentication Method
- RADIUS, Radio Service Set ID (SSID), Extensible Authentication Protocol (EAP)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az
Aerial
- Antenna
- External detachable
- Antenna Qty
- 2
- 1 x 1000Base-T - RJ-45
- EN 300.328, EN 301.489.1, EN 301.489.17, FCC Part 15 B, FCC Part 15 C, EN 60950-1, FCC Part 15 E, EN 301.893, EN 60601-1-2, DGT
- PoE
- Power Device
- External power adapter
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
