With the 802.11ac Wi-Fi technology, the ZyXEL ARMOR X1 dual-band wireless Gigabit access point/range extender delivers great speeds to your Wi-Fi devices. It covers all your home network requirements with the optimal Wi-Fi and Gigabit Ethernet for better online experience. The ARMOR X1 enables 4K/UHD video streaming or lag-free online video gaming by extending your existing fast 802.11ac Wi-Fi network at home.
Easy setup for your Wi-Fi network coverage needs
The ZyXEL ARMOR X1 works as an access point, a Wi-Fi extender or a wireless client. Simply select the mode needed for your network environment using eaZy123 setup wizard to enjoy the high-speed network instantly. -
Make it the way you want it
You have the freedom to choose - adding wireless speeds with reliable Gigabit Ethernet connection to different floor or rooms, easily extending 802.11ac wireless coverage from your existing 802.11ac router, or providing Internet connection to your media devices wirelessly from the router. Choose what you need for your wireless network at home so the ZyXEL ARMOR X1 will play the role for you. -
Prioritize wireless performance as needed
The ZyXEL ARMOR X1 provides the 802.11ac dual-band wireless technology, with which you can instantly enjoy wireless connectivity for daily use. Choose the Range mode for maximum Wi-Fi coverage or Speed mode to boost speedy connection for video streaming and throughput-intensive applications. -
Design with simplicity to fit your home
It fits into shelves like a book, sits on the desk beside the telephone or stands next to the ultra-thin TV perfectly - just place it the way you'd like. All you need to do is to decide the best spot to connect your wireless devices to the router and power it up. -
Gigabit Ethernet maximizes wired performance
With four Gigabit Ethernet ports, the ZyXEL ARMOR X1 has been designed for reliable, high-performance video streaming with speeds much faster than typical Ethernet connections, and the device makes it easy to connect multiple wired devices like smart TV, laptop, game console or NAS.
- Zyxel ARMOR X1 - radio access point - Wi-Fi 5
- Radio access point
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- 3.7 cm x 13.4 cm x 21.8 cm
- 396 g
- 3.7 cm
- 13.4 cm
- 21.8 cm
- 396 g
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 2100 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Power, signal strength, WPS
- Auto-uplink (auto MDI/MDI-X), repeating mode, Wi-Fi Multimedia (WMM) support, Auto Channel Select (ACS), Wi-Fi Protected Setup (WPS), hidden SSID, reset button, Wireless Client Mode, wireless extender mode
- Encryption Algorithm
- WPA-PSK, WPA2-PSK, WEP
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
Aerial
- Antenna
- Internal
- Antenna Qty
- 6
- 4 x 1000Base-T - RJ-45
- Cables Included
- 1 x network cable
- RoHS, LVD
- Power Device
- External power adapter
- 10.2 Watt
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
