Zyxel ANT3316 5Ghz 16dBi 2 Element MIMO Directional Outdoor Antenna
Quicklinx: BW5MWS00 Mfr#: ANT3316-ZZ0101F
The ZyXEL antennas are available in various space, directionality, gain and range capabilities in different form factors. With appropriately coupled antennas and APs, businesses will enjoy prefect WLAN environments with superior coverage, better reliability and higher data rates in all kinds of facilities. In addition, the ZyXEL low-loss cables can be used to extend the distance between any ZyXEL 2.4 GHz and 5 GHz AP and the antenna through N-plug or RP-SMA connectors.
Zyxel ANT3316 - antenna
Antenna
21 cm x 21 cm x 7.3 cm
800 g
Product Material
ABS plastic
Grey white
Aerial Placing / Mounting
Outdoor
Frequency Range
5.15 - 5.875 GHz
Gain
15 dBi, 16 dBi
Directivity
Directional
Antenna
Product Material
ABS plastic
21 cm
21 cm
7.3 cm
800 g
Enclosure Colour
Grey white
Aerial
Outdoor
Frequency Range
5.15 - 5.875 GHz
Gain
15 dBi, 16 dBi
Directivity
Directional
Voltage Standing Wave Ratio (VSWR)
2.0:1
Horizontal Beamwidth
19°
Vertical Beamwidth
21°
Impedance
50 Ohm
Cabling & Wiring
Connector Provided
2 x N connector male
UV protection, MIMO technology
-40 °C
80 °C
