Zyxel ANT1314 2.4Ghz 14dBi 2 Element MIMO Directional Antenna
Quicklinx: BW5KWS00 Mfr#: ANT1314-ZZ0101F
The ZyXEL antennas are available in various space, directionality, gain and range capabilities in different form factors. With appropriately coupled antennas and APs, businesses will enjoy prefect WLAN environments with superior coverage, better reliability and higher data rates in all kinds of facilities. In addition, the ZyXEL low-loss cables can be used to extend the distance between any ZyXEL 2.4 GHz and 5 GHz AP and the antenna through N-plug or RP-SMA connectors.
Zyxel ANT1314 - antenna
Antenna
56 cm x 12 cm x 14.5 cm
800 g
Product Material
ABS plastic
Grey
Aerial Placing / Mounting
Outdoor
Frequency Range
2.4 - 2.5 GHz
Gain
14 dBi
Directivity
Directional
Antenna
Product Material
ABS plastic
56 cm
12 cm
14.5 cm
800 g
Enclosure Colour
Grey
Aerial
Outdoor
Frequency Range
2.4 - 2.5 GHz
Gain
14 dBi
Directivity
Directional
Voltage Standing Wave Ratio (VSWR)
2.0:1
Horizontal Beamwidth
60°
Vertical Beamwidth
13°
Impedance
50 Ohm
Cabling & Wiring
Connector Provided
2 x N connector male
UV protection, MIMO technology
-40 °C
80 °C
