The ZyXEL antennas are available in various space, directionality, gain and range capabilities in different form factors. With appropriately coupled antennas and APs, businesses will enjoy prefect WLAN environments with superior coverage, better reliability and higher data rates in all kinds of facilities. In addition, the ZyXEL low-loss cables can be used to extend the distance between any ZyXEL 2.4 GHz and 5 GHz AP and the antenna through N-plug or RP-SMA connectors.
- Zyxel ANT1310 - antenna
- Product Type
- Antenna
- 13.3 cm x 13.3 cm x 4.2 cm
- 130 g
- Product Material
- ABS plastic
- White
- Aerial Placing / Mounting
- Ceiling mountable, indoor
- Frequency Range
- 2.3 - 2.7 GHz
- Gain
- 9 to 10 dBi
- Directivity
- Directional
- 2 years warranty
- Product Type
- Antenna
- Product Material
- ABS plastic
- 13.3 cm
- 13.3 cm
- 4.2 cm
- 130 g
- Enclosure Colour
- White
Aerial
- Frequency Range
- 2.3 - 2.7 GHz
- Gain
- 9 to 10 dBi
- Directivity
- Directional
- Voltage Standing Wave Ratio (VSWR)
- 1.5:1
- Horizontal Beamwidth
- 51°, 66°
- Vertical Beamwidth
- 51°, 66°
- Impedance
- 50 Ohm
Cabling & Wiring
- Connector Provided
- 2 x SMA male
- Mounting Kit
- Included
- UV protection, MIMO technology
- Limited warranty - 2 years
- -10 °C
- 55 °C
