Zyxel AMG1302-T11C Wireless Router/DSL Modem 802.11b/g/n - Desktop
Quicklinx: CKWHWS00 Mfr#: AMG1302-T11C-GB01V1F
It is designed with multiple WAN function, suitable for future FTTH deployment with optimized CAPEX. Additionally, it integrates IEEE 802.11 b/g/n access point and 10/100 Ethernet switch for Local Area Network (LAN) access.
2.4 GHz 11n (2x2) for superior performance and coverage
ZyXEL AMG1302-T11C Wireless N ADSL2+ Gateway features 802.11n technology to provide the ultimate solution for both speed and coverage. With 802.11n wireless data rates of up to 300 Mbps, the AMG1302-T11C provides stable, reliable wireless connections for high-speed data and multimedia applications.
Wi-Fi Protection Setup (WPS)
Wi-Fi Protected Setup (WPS) is a standard for easy, secure establishment of wireless networks. It makes configuration of secure personal wireless networks as simple as pushing a button or entering a Personal Identification Number (PIN) code.
Robust SPI Firewall security
The SPI Firewall works on the network layer by examining header and footer of a packet and ensures the packet belongs to a valid session. Based on Stateful Packet Inspection (SPI), Denial of Service (DoS) and Distributed DoS (DDoS) features, ZyXEL AMG1302-T11C provides the first-line defense against hackers, network intruders and other harmful threats.
Quality of Service (QoS) support
ZyXEL AMG1302-T11C comes equipped with essential ATM QoS features as well. Service providers can freely design their QoS policies and prioritize mission-critical services such as IPTV and VoIP based on their service plans.
TR-069 remote management
With the TR-069 standard management specifications, ZyXEL AMG1302-T11C allows service providers to manage and configure client devices remotely without interfering end users. This unique feature not only offers true "plug-and-play" experience but also reduces deployment complexity, and it saves operating and maintenance costs for service providers.
Multiple WAN for simplified ISP logistics and optimized CAPEX
When customers migrate from ADSL2+ to PON or LTE, service providers are not required to invest on new CPE and replace them at customer sites; all they have to do is keeping the ZyXEL AMG1302-T11C by unplugging the DSL line and plug an Ethernet cable into the Ethernet WAN port. The existing customer AMG1302-T11C can be retained for terminating IP connection, but now it's via the Ethernet WAN interface.
  • Superior performance and coverage
    The ZyXEL AMG1302-T11C features 802.11n technology to provide an advanced solution for both speed and coverage. It provides stable, reliable wireless connections for high-speed data and multimedia applications.
  • Robust SPI firewall security
    The SPI firewall works on the network layer by examining header and footer of a packet and ensures the packet belongs to a valid session. Based on SPI, DoS and DDoS features, the ZyXEL AMG1302-T11C provides the first-line defense against hackers, network intruders and other harmful threats.
  • QoS support
    ZyXEL AMG1302-T11C comes equipped with ATM QoS features as well. Service providers can freely design their QoS policies and prioritize mission-critical services such as VoIP, based on their service plans.
Zyxel AMG1302-T11C - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2, ADSL2+, READSL, ADSL over POTS
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Network / Transport Protocol
PPTP, IPSec, PPPoE, DDNS
Routing Protocol
RIP-1, RIP-2, IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, HTTP, HTTPS, CLI, TR-069
VoIP Protocols
SIP
Firewall protection, NAT support, IGMP snooping, Stateful Packet Inspection (SPI), packet filtering, ALG support, IPv6 support, VPN passthrough, URL filtering, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, port forwarding, reset button, DHCP relay, DHCP client, Denial of Service (DoS), IGMP proxy, Distributed DoS (DDoS)
IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP
15.8 cm x 11.45 cm x 2.2 cm
186 g
United Kingdom
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Routing Protocol
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP, EN 60950-1
Status Indicators
Power, WLAN, LAN, WPS, Internet, DSL
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.3 (G.DMT.bis), ITU G.992.4 (G.lite.bis), ITU G.992.5, ITU G.992.5 Annex M, ITU G.992.5 Annex L
IP Telephony
VoIP Protocols
SIP
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11
Aerial
Aerial
Internal
Antenna Qty
2
External power adapter
4.9 Watt
1 x network cable , 1 x modem cable
United Kingdom
15.8 cm
11.45 cm
2.2 cm
186 g
10 - 90% (non-condensing)
