Zyxel 802.11bgn High Power Wireless Access Point
Quicklinx: BBTYWS00 Mfr#: NWA1100-NH-EU0101F
Type: Radio access point
Connectivity: Wireless
Speed: 300Mbps
Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Compatibility: PC
  • IEEE 802.11n
15 in stock
£58.91 ex VAT
£70.69 inc VAT
Long-range, Powerful and Optimal Wi-Fi Connectivity for Businesses
In the so-called BYOD trend, more than 80% of employees use at least one personally owned mobile device such as smart phones or tablets for business; however data transmission with these mobile devices is sometimes unstable because of their weak output power. To be the best accommodate mobile devices in the network, the new ZyXEL NWA1100-NH 802.11 b/g/n Long Range PoE Access Point features high output power and antenna gain to optimize wireless coverage and signal quality that are four times better for improved device connectivity. In addition, advanced management features also relieve tiresome configuration tasks for more than a few access points (APs). The NWA1100-NH is the best solution for businesses to streamline Wi-Fi connections.
Boost Wi-Fi coverage for more than 30%
Today, speed is no longer an issue for Wi-Fi, but coverage still is. That is, longer distance causes serious drop in throughput. The boosted output power of ZyXEL NWA1100-NH improves throughput in the same distance and thus extends the coverage comparing other APs with regular output strength. With even the same number of AP deployed, users can still enjoy better performance within the coverage.
Adaptive to the existing wiring infrastructure
Compliant with the 802.3af standard consuming power of less than 15 Watts, the NWA1100-NH not only saves energy but also adopts latency switches; as such there's no need to change the wired infrastructure and it helps businesses to minimize extra cost on new equipment setup.
ZyXEL ONE Network experience
Aiming for relieving our customers from repetitive operations of deploying andmanaging a network, ZyXEL ONE Network is designed to simplify the configuration, management, and troubleshooting, allowing our customers to focus on the business priorities. ZyXEL ONE Network presents an easy-to-use tool, ZyXEL ONE Network Utility (ZON Utility), to realize speed network setup. ZyXEL Smart Connect* allows ZyXEL networking equipment to be aware and recognize each other and further facilitating the network maintenance via one-click remote functions such as factory reset or power cycling. ZyXEL ONE Network redefines the network integration across multiple networking products from switch to Wi-Fi AP and to Gateway.
Secured Wi-Fi access control
The devices requiring Wi-Fi connectivity are mostly mobile units and are mostly not corporate assets, so management to access privileges of such Wi-Fi clients is definitely required to secure the business network. The ZyXEL NWA1100-NH offers various ways to verify Wi-Fi clients in order to keep unauthorized users from connecting to the network or taking network resources.
  • Boost Wi-Fi coverage for more than 30%
  • Adaptive to the existing wiring infrastructure
  • ZyXEL ONE Network experience
    Aiming for relieving the customers from repetitive operations of deploying andmanaging a network, ZyXEL ONE Network is designed to simplify the configuration, management, and troubleshooting, allowing the customers to focus on the business priorities. ZyXEL ONE Network presents an easy-to-use tool, ZyXEL ONE Network Utility (ZON Utility), to realize speed network setup. ZyXEL Smart Connect allows ZyXEL networking equipment to be aware and recognize each other and further facilitating the network maintenance via one-click remote functions such as factory reset or power cycling. ZyXEL ONE Network redefines the network integration across multiple networking products from switch to Wi-Fi AP and to Gateway.
Zyxel NWA1100-NH - radio access point
Radio access point
External
Europe
Frequency Band
2.4 GHz
Maximum number of configured SSIDs: 8
Power Over Ethernet (PoE) Supported
PoE
15.3 cm x 11 cm x 3.8 cm
240 g
Radio access point
15.3 cm
11 cm
3.8 cm
240 g
Europe
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, CLI
Frequency Band
2.4 GHz
VLAN support, MAC address filtering, IPv6 support, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, 2T2R MIMO technology, DHCP client, ZyXEL One Network (ZON)
Encryption Algorithm
MD5, PEAP, TTLS, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise, WEP
Authentication Method
RADIUS, Extensible Authentication Protocol (EAP)
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az
Aerial
Antenna
External detachable
Antenna Qty
2
Gain Level
5 dBi
1 x 1000Base-T (PoE) - RJ-45
MTBF
1,018,459.6 hours
ETSI, EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, EN 301.489.1, EN 301.489.17, FCC Part 15 B, FCC Part 15 C, IEC 60950-1, EN 60950-1, BSMI CNS 13438, EN 60601-1-2, DGT, EN 300 328, BSMI CNS 14336-1
PoE
External power adapter
60 °C
10 - 95% (non-condensing)
BBTY C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
BBTY C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.23
BBTY C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.98
BBTY C2G 2m Cat6a Shielded Patch - Blue In Stock £7.38
Speed: 300Mbps
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Brand: Zyxel
Price Range Ex VAT: 50 - 100
