Product
Zyxel 802.11agn 300Mbps Dual-Band Wireless Access Point 91-005-355001B
The Wireless Expert
Quicklinx: 8MFLWS00 Mfr#: 91-005-355001B
  • IEEE 802.11n
Within business today companies continually face the challenge of providing wireless access to guests and mobile employees without compromising security. To address this situation ZyXEL has developed the NWA5160N WLAN AccessPoint. The solution is designed to deliver high performance 11n wireless to provide seamless mobility in medium to large campus and secure distributed enterprise environments.
  • Central configuration
    This w secure WLAN solution is based on the ZyXEL NWA5160N managed access points that scales up to 240 access points (APs) and provides comprehensive wireless coverage.
  • Better wireless experience
    Central administration simplifies planning immensely. The managed access points are first installed at the most suitable locations for WLAN reception. Areas with insufficient coverage or too low data speeds can be made accessible with additional managed access points. The best results can be obtained however when a site survey is carried out enabling a simplified installation and better wireless experience.
  • Captive portal
    A captive portal intercepts all network traffic regardless of address or port until users authenticate their identity through a designated login web page. As an added security measure, the NXC contains captive portal functionality; this means that all web page requests can be initially redirected to a special web page that requires guests to authenticate their sessions.
Zyxel NWA-5160N - radio access point
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Power Over Ethernet (PoE) Supported
PoE
22.5 cm x 17.8 cm x 6 cm
0.77 kg
Radio access point
22.5 cm
17.8 cm
6 cm
0.77 kg
External
Wireless
Remote Management Protocol
SSH, CLI
DHCP support
Encryption Algorithm
WPA, WPA2
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
3
1 x 1000Base-T - RJ-45
PoE
8 Watt
20 - 90% (non-condensing)
8MFL C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
8MFL C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.20
8MFL C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.76
8MFL C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £45.82
