The XGS-4526 offers complete Layer-3 features to make it the preferred choice for real routing networks in the enterprise. The XGS-4526 provides 20 1000Base-T ports, 4 Gigabit dual-personalities, and 1 open slot for the optional 10-Gigabit uplink port module, the XGS-4526 is ideal for small and medium enterprises seeking to build a high performance network.
The ZyXEL XGS-4526 provides wirespeed Layer-2 Gigabit switching of up to 144Gpbs, along with advanced Layer-3 switching, multicasting, resiliency including OSPF, DVMRP and VRRP for connectivity requirements. Its four flexible speeds - 10/100/1000Mbps and 10Gbps performance - also provide greater flexibility to the core networks or high-performance servers.
The ZyXEL XGS-4526 supports Intelligent QoS features to regulate network traffics for the best performance. Taking advantage of Class of Service (CoS) and Differentiated Services Code Point (DSCP) supports, administrators can easily classify and perform traffic prioritizing for critical business applications such as VoIP and video conferencing. In addition, the 4500 Series provides advanced bandwidth control with granularity of 64kbps and 8 hardware priority queues that bring better bandwidth administration to network operators.
The ZyXEL XGS-4526 supports the VRRP routing protocol for failover transmissions. The second DC power source, called BPS, protects the device from internal AC power supply failures, while the IEEE802.3ad Link aggregation reduces network downtime by providing more packet paths and bandwidth aggregation to critical paths. The Gigabit connectivity not only gives superb transmission bandwidth, but also allows users to set up Gigabit aggregation for securing critical transmission paths. The IEEE802.1w Rapid spanning tree (RSTP) also allows immediate recovery from failed links by sending packets via a backup link path.
Managed L2 and L3 gigabit connectivity for lower future expansion and upgrading costs
The ZyXEL XGS-4526 provides wirespeed Layer-2 Gigabit switching of up to 144Gpbs, along with advanced Layer-3 switching, multicasting, resiliency including OSPF, DVMRP and VRRP for connectivity requirements. Its four flexible speeds - 10/100/1000Mbps and 10Gbps performance - also provide greater flexibility to the core networks or high-performance servers. -
Intelligent QoS for mission critical applications ensure best network status
The ZyXEL XGS-4526 supports Intelligent QoS features to regulate network traffics for the best performance. Taking advantage of Class of Service (CoS) and Differentiated Services Code Point (DSCP) supports, administrators can easily classify and perform traffic prioritizing for critical business applications such as VoIP and video conferencing. In addition, the 4500 Series provides advanced bandwidth control with granularity of 64kbps and 8 hardware priority queues that bring better bandwidth administration to network operators. -
Robust and high-availability system design guarantee non-stop operations
- Zyxel XGS-4526 - switch - 24 ports - Managed
- Switch - 24 ports - L3 - Managed
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 + 4 x shared SFP
- MAC Address Table Size
- 8K entries
- Routing Protocol
- OSPF, RIP-1, RIP-2, IGMPv2, IGMP, DVMRP, VRRP, static IP routing, IGMPv3
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, SSH-2
- Flow control, routing, Layer 4 switching, Layer 3 switching, Layer 2 switching, VPN support, auto-negotiation, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, packet filtering, port mirroring, DiffServ support, manageable, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, High Availability, IP address filtering, Weighted Fair Queuing (WFQ), ZyXEL iStacking Technology, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, VLAN Stacking, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, DHCP server
- IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ag, IEEE 802.1ab (LLDP)
- Power
- AC 120/230 V (50/60 Hz)
- 43.8 cm x 31 cm x 4.4 cm
- 7 kg
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- 8K entries
- Routing Protocol
- Encryption Algorithm
- SSL, TLS
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- Status Indicators
- Port status, port transmission speed, power, system, alarm, RPS (Redundant Power Supply)
- 24 x 1000Base-T RJ-45 , 1 x RJ-45 management , 1 x console DB-9 management , 4 x SFP (mini-GBIC)
- Expansion Slots
- 1 (total) / 1 (free) x Expansion Slot
- Power Device
- Internal power supply
- Voltage Required
- 62.8 Watt
- Redundant Power System (RPS) connector
- EMC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15 A
- 43.8 cm
- 31 cm
- 4.4 cm
- 7 kg
- 0 °C
- 45 °C
- 10 - 90%
