Zotac GeForce GTX 1060 Mini 6GB GDDR5 PCIe 3.0 x16 DVI HDMI DisplayPort
Quicklinx: CP8PWS00 Mfr#: ZT-P10600A-10L
The ZOTAC GeForce GTX 1060 graphics card is loaded with innovative gaming technologies, making it the perfect choice for the high-definition games. Powered by NVIDIA Pascal, the ZOTAC GeForce GTX 1060 delivers brilliant performance that opens the door to virtual reality and beyond.
  • Great performance
    With ultra-fast FinFET and next-generation memory technologies, plus support for DirectX 12 features, the GeForce GTX 1060 is a quantum leap in performance and power efficiency. This means you can count on the faster, smoother, more power-efficient gaming experiences.
  • Breakthrough gaming technologies
    Get the NVIDIA GameWorks technologies for smooth gameplay, cinematic experiences, and 360-degree image capture - even in VR. Plus, get the performance to drive the modern displays, including VR, ultra-high-resolution, and multiple monitors.
  • VR Ready
    Discover next-generation VR performance, low latency, and Plug-and-Play compatibility with headsets - driven by NVIDIA VRWorks technology- VR audio, physics, and haptics let you hear and feel every moment with two super-compact solutions.
  • Silent innovation
    Fans stop for complete silence when below a set temperature threshold.
  • Extending fan life
    Less usage means less wear and longer fan life.
  • FireStorm
    Redesigned from the ground up, extract every ounce of performance from your ZOTAC graphics card with Firestorm. Tweaking and tuning is quick and easy with an optimized user interface that presents users with clock speed adjustments, fan control, GPU monitoring functions, and much more.
ZOTAC GeForce GTX 1060 Mini - graphics card - GF GTX 1060 - 6 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1060
6 GB GDDR5
Core Clock
1506 MHz
Boost Clock
1708 MHz
CUDA Cores
1280
Effective Memory Clock
8 GHz
Memory Interface
192-bit
Max Monitors Supported
4
DVI-I (dual link) , 3 x DisplayPort , HDMI
API Supported
OpenCL, DirectX 12, OpenGL 4.5, Vulkan, DirectX 12.1
17.4 cm x 11.115 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1506 MHz
Boost Clock
1708 MHz
CUDA Cores
1280
VR Ready
4
API Supported
NVIDIA G-Sync ready, NVIDIA GameStream, Nvidia GeForce GTX VR Ready, NVIDIA GPU Boost 3.0, NVIDIA Ansel, HDCP
Size
6 GB
GDDR5 SDRAM
Effective Clock Speed
8 GHz
Bus Width
192-bit
Microsoft Windows 7 / 8 / 10
Required Power Supply
400 W
Additional Requirements
6 pin PCI Express power connector
120 Watt
17.4 cm
11.115 cm
