Zoostorm Micro Pentium G4400 4GB 500GB Windows 10 Home
Quicklinx: CF70WS00 Mfr#: 7877-0225
  • Pentium
  • DVD-RW
Get more done in less time with the help of a Zoostorm Delta Micro PC.
For busy office environments in education and business, this PC is an all-round computer with the capacity to help you manage your daily computing and administrative tasks with ease.
When you are relied upon for your specialist administrative skills, you need the best PC to support you. This PC is designed to help you finish work more quickly - freeing up time to spend on other work.
Getting started on your working day takes seconds thanks to the Intel Pentium processor and 4GB RAM. Then you can get on with your most urgent tasks without waiting for the system to come to life.
Because most of your work is done using your computer, you need to feel confident you can rely on it to be fast as it opens, transfers and processes the information you need for the task in hand.
When you need personal storage space, there is 500GB available for all the presentations, videos, images, documents and downloaded files you need instant access to.
A generous number of USB ports (front and back) mean you can plug in a USB stick and quickly copy a file to share with colleagues. And the latest USB 3.0 version transfers data even faster than before. The DVD-RW drive comes into its own for copying and sharing videos produced by your school or company.
Time-saving tools are always welcome and the Zoostorm Delta Micro comes with Windows 10 Professional already installed. You can immediately benefit from the 'search and find' help available through Microsoft's digital assistant, Cortana, making it easy to retrieve the files you need to continue working on. Or you can set reminders for meetings - practical help for everyone with a hectic schedule.
This new slimmer design frees up valuable space at your desk. Using a VESA stand you can fix the monitor to the PC and immediately gain a neater, tidier work area around you. What's more, it's coated in a scratch-resistant paint to keep it looking smart on your desk throughout its working life.
Made in Britain and put through rigorous tests, Zoostorm PCs leave our factory only when 100% checked for quality. Our service includes the support of a UK based telephone helpline.
Zoostorm Delta Micro - Pentium G4400 3.3 GHz - 4 GB - 500 GB
Personal computer - ultra small form factor
1 x Intel Pentium G4400 / 3.3 GHz ( Dual-Core )
RAM
4 GB (installed) / 32 GB (max)
Hard Drive
1 x 500 GB - SATA
Optical Storage
DVD-RW
Graphics Controller
Intel HD Graphics 510
3 Year On-site Warranty
Personal computer
Product Form Factor
Ultra small form factor
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
RAM
Installed Size
4 GB / 32 GB (max)
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA
Optical Storage
DVD-RW
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Bays
1 external 5.25" , Internal 3.5"
Slots
1 (total) / 0 (free) x CPU
