Zoostorm Micro Pentium G4400 4GB 120GB SSD Windows 10 Home
Quicklinx: CF71WS00 Mfr#: 7877-0220
  • Pentium
  • DVD-RW
For schools and in small to medium sized businesses, the Zoostorm Delta Micro PC gives you the computing power to take care of everyday tasks while fitting neatly into your work space.
Compact yet powerful, the Zoostorm Delta Micro Desktop PC has the capacity for constant everyday tasks without the big price ticket.
If you prefer a decluttered desk, the PC can instantly become an all-in-one unit by attaching the monitor (using a VESA mount).
The Zoostorm Delta Micro PC is built to endure constant workday use in busy environments in schools, in workplaces and at home.
The Intel Pentium processor boots up in seconds and quickly moves you through the applications and files you need to work with. Photos and videos can be edited with ease and graphics are shown with HD precision. Multi-tasking is a breeze with this PC.
Housed inside an ultra-slim case, its surface is protected by ‘Storm Coat’ scratch-resistant paint.
There are 4 USB ports. Two are the latest USB 3.0 type for faster exchange of files. And two are on the front giving easy access for connecting printers and other devices.
Windows 10 Professional (pre-installed) comes with Cortana – your personal assistant, helping you to remember appointments, retrieve information more easily and complete routine tasks.
Using the DVD-RW drive, you can copy video disks for sharing and reviewing among your team.
British made, every Zoostorm Delta PC is thoroughly tested for quality giving unbeatable performance for the price. Every customer can benefit from our UK-based support line if you need help.
Zoostorm Delta Micro - Pentium G4400 3.3 GHz - 4 GB - 120 GB
Personal computer - ultra small form factor
1 x Intel Pentium G4400 / 3.3 GHz ( Dual-Core )
RAM
4 GB (installed) / 32 GB (max)
Hard Drive
1 x SSD 120 GB - SATA
Optical Storage
DVD-RW
Graphics Controller
Intel HD Graphics 510
3 Year On-site Warranty
Personal computer
Product Form Factor
Ultra small form factor
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
RAM
Installed Size
4 GB / 32 GB (max)
Hard Drive
SSD
1 x 120 GB
Interface Type
SATA
Optical Storage
DVD-RW
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Bays
1 external 5.25" , Internal 3.5"
Slots
1 (total) / 0 (free) x CPU
