Zoostorm Micro Core i7-6700 8GB 1TB Windows 10 Home
Quicklinx: CF77WS00 Mfr#: 7877-0228
  • Core i7
  • DVD-RW
Boost your productivity with the help of this Zoostorm Delta Micro PC.
This computer is designed and built to help you multi-task, especially in schools and in business where there are constant demands on your time.
The Intel Core i7 processor together with 8GB RAM gives the power to swiftly send emails, create graphic presentations and edit videos while using your school or company information systems to complete your everyday workload. From switching on (in seconds) the Zoostorm Delta Micro keeps workflow running smoothly allowing you to get through a multitude of tasks in one day.
A super slim PC which gives more space on your desk and unbeatable computing performance for the money, it is perfect for a busy office environment in a school or business.
Housed in an ultra-slim casing and coated in scratch-free paint, the PC fits neatly into your workspace taking up the least possible room. For more space-saving, have the monitor fitted to the PC using a VESA mount and enjoy a less cluttered desk.
A generous 10 USB connections (front and back) are there for speedy data transfer when you're asked to share files with colleagues. And when it needs to happen fast, choose one of the latest USB 3.0 connections.
You won't run out of space during the life of this PC thanks to its massive 1TB of storage space on the hard disk. It'll keep thousands of hours of presentations and documents along with photos and videos.
A personal assistant, Cortana, comes with the pre-installed Windows 10 Professional. Use this digital service to remind you about meetings, deadlines and the location of files you need to retrieve and work on.
This PC comes with 3 audio jacks for the times when you need to connect headphones, microphones or speakers.
Made in Britain and put through rigorous tests, Zoostorm PCs leave our factory only when 100% checked for quality. Our service includes the support of a UK based telephone helpline.
Zoostorm Delta Micro - Core i7 6700 3.4 GHz - 8 GB - 1 TB
Personal computer - ultra small form factor
1 x Intel Core i7 (6th Gen) 6700 / 3.4 GHz ( 4 GHz ) ( Quad-Core )
Cache Memory
8 MB L3 Cache
Cache Per Processor
8 MB
RAM
8 GB (installed) / 32 GB (max)
Hard Drive
1 x 1 TB - SATA
Optical Storage
DVD-RW
Graphics Controller
Intel HD Graphics 530
3 Year On-site Warranty
Personal computer
Product Form Factor
Ultra small form factor
Processor / Chipset
CPU
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
L3 Cache - 8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 32 GB (max)
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA
Optical Storage
DVD-RW
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Bays
1 external 5.25" , Internal 3.5"
Slots
1 (total) / 0 (free) x CPU
