Product
Zoostorm Micro Core i5-6400 8GB 500GB Windows 10 Home
Quicklinx: CF73WS00 Mfr#: 7877-0227
  • Core i5
  • DVD-RW
Multi-task with ease using the Zoostorm Delta Micro PC.
This computer is designed to lighten your administrative load, especially if you work in a busy educational, commercial or office environment. It is built to complete everything faster from first starting up to the multitude of tasks which are crammed into your day.
The Intel Core i5 processor is the power behind your work, continuing to run smoothly, helping you keep files organised and sharing them with colleagues as you switch between apps and websites. If you regularly work on media files such as graphic presentations, photos, videos and images this PC promptly takes care of editing without causing you to wait for it to finish processing.
The 500GB hard drive gives you ample storage for thousands of videos and documents and keeps them at your fingertips for when needed. For video copying, there is a rewritable drive.
With the pre-installed Windows 10 Professional comes Cortana, an extra pair of virtual hands. As your digital personal assistant, it can be set up to remind you when urgent meetings are due, to help locate important files and to help you find previously visited websites when you're looking up information.
Housed in an ultra-slim casing and protected by scratch-free paint, the PC fits neatly into your workspace taking up the minimum of room. Have the monitor fitted to the PC using a VESA mount will save even more space.
Transferring data to memory sticks becomes easier using the USB ports on the front and back (there are a generous 10 of them). And when you need it to happen faster, choose one of the latest USB 3.0 connections.
A personal assistant, Cortana, comes with the pre-installed Windows 10 Professional. This is a virtual service you can use to remind you about events, deadlines and the location of files you need to work on. A great time saver for your busy day.
This PC comes with 3 audio jacks which is useful if you're often asked to connect headphones, microphones or speakers.
Made in Britain and put through stringent tests, Zoostorm PCs leave our factory only when 100% checked for quality. Our service includes the support of a UK based telephone helpline.
Zoostorm Delta Micro - Core i5 6400 2.7 GHz - 8 GB - 500 GB
Personal computer - ultra small form factor
1 x Intel Core i5 (6th Gen) 6400 / 2.7 GHz ( 3.3 GHz ) ( Quad-Core )
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
8 GB (installed) / 32 GB (max)
Hard Drive
1 x 500 GB - SATA
Optical Storage
DVD-RW
Graphics Controller
Intel HD Graphics 530
3 Year On-site Warranty
Personal computer
Product Form Factor
Ultra small form factor
Processor / Chipset
CPU
Max Turbo Speed
3.3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
8 GB / 32 GB (max)
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA
Optical Storage
DVD-RW
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Bays
1 external 5.25" , Internal 3.5"
Slots
1 (total) / 0 (free) x CPU
