Zoostorm Micro Core i3-6100 4GB 500GB Windows 10 Home
Quicklinx: CF6CWS00 Mfr#: 7877-0226
  • Core i3
  • DVD-RW
Complete more work in less time with the help of a Zoostorm Delta Micro Desktop PC.
For busy office environments in schools and businesses, this computer is welcome support for everyone with a multitude of administrative responsibilities.
Your new Zoostorm Delta Micro PC will help to make your working day go much faster thanks to Intel i3 processing power and a 4GB RAM. From the moment you switch on the PC, its generous boost of power boots up in seconds to get the day off to an efficient start.
Whether you are creating graphic presentations, copying DVDs and CDs to share, or accessing your company or school's information portal, the Zoostorm Delta Micro will handle everyday tasks with ease. And it is built to take away the worry of the system slowing down and delaying your work.
Housed in a super slim casing and coated in scratch-free paint, the PC fits unobtrusively into your workspace taking up the minimum of room. By having the monitor fitted to the PC using a VESA mount, you can save even more space.
A generous hard drive of 500GB offers thousands of hours of storage and keeps your most-used files to hand for ease of access.
Placing USB ports on the front makes file copying to memory sticks easier - and faster thanks to the latest USB 3.0 technology.
A personal assistant, Cortana, comes with the pre-installed Windows 10 Professional. This is a virtual service you can use to remind you about events, deadlines and the location of files you need to work on. A great time saver for your busy day.
Made in Britain and put through stringent tests, Zoostorm PCs leave our factory only when 100% checked for quality. Our service includes the support of a UK based telephone helpline.
Zoostorm Delta Micro - Core i3 6100 3.7 GHz - 4 GB - 500 GB
Personal computer - ultra small form factor
1 x Intel Core i3 (6th Gen) 6100 / 3.7 GHz ( Dual-Core )
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 32 GB (max)
Hard Drive
1 x 500 GB - SATA
Optical Storage
DVD-RW
Graphics Controller
Intel HD Graphics 530
3 Year On-site Warranty
Personal computer
Product Form Factor
Ultra small form factor
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 32 GB (max)
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA
Optical Storage
DVD-RW
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Bays
1 external 5.25" , Internal 3.5"
Slots
1 (total) / 0 (free) x CPU
