Zoostorm Elite Pentium G4400 4GB 500GB Windows 10 Pro
Quicklinx: CF6MWS00 Mfr#: 7877-0216
  • Pentium
  • DVD-RW
Get your work done faster with the Zoostorm Delta Elite Desktop PC.
For everyday computing, this PC has the power for constant use in schools, offices and light industrial environments.
The Intel Pentium processor with 4GB RAM powers up immediately and gets to work on your daily tasks. You can rely on this PC for non-stop performance as you work on presentations, documents, emails, internet searches and your business or school information portal. It's built for multi-tasking.
Ample space on the 500 GB hard drive will store thousands of files, making them instantly available the moment you need them.
For back-ups, sharing and printing, use one of the 10 USB ports (they're located front and back). If you want a faster transfer of data to the USB memory stick, use one of the latest-technology USB3.0 ports.
The DVD rewritable disk is useful for file sharing: you can copy videos and photos created at your school or company and give them to colleagues.
With Windows 10 Professional comes personal digital assistant 'Cortana'. You can instruct it to remind you about events and to help you find apps, files and previously visited websites - invaluable time-saving support. What's more, the security in Windows 10 Professional will safeguard your information and enable remote log in when you're working away from the office.
The PC's case is coated in a scratch-resistant paint to protect its surface from the rigours of working life. This makes it especially suited to heavy-use environments in education, light industry and small business.
Three audio jacks are provided for the times when you need to connect headphones, microphones and speakers.
British made and rigorously tested, Zoostorm PCs leave our factory only when 100% checked for quality.
Included in our service is the support of a UK based telephone helpline to answer all your questions.
Zoostorm Delta Elite - Pentium G4400 3.3 GHz - 4 GB - 500 GB
Personal computer - small form factor
1 x Intel Pentium G4400 / 3.3 GHz ( Dual-Core )
Cache Memory
3 MB L3 Cache
Cache Per Processor
3 MB
RAM
4 GB (installed) / 32 GB (max)
Hard Drive
1 x 500 GB - SATA
Optical Storage
DVD-RW
Graphics Controller
Intel HD Graphics 510
13.2 cm x 32.8 cm x 28.4 cm
3 Year On-site Warranty
Personal computer
Product Form Factor
Small form factor
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
L3 Cache - 3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 32 GB (max)
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA
Optical Storage
DVD-RW
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Bays
1 (total) / 0 (free) x external 5.25"
Slots
1 (total) / 0 (free) x CPU
13.2 cm
32.8 cm
28.4 cm
