Zoostorm Elite Core i5-6400 8GB 1TB Windows 10 Pro
Quicklinx: CF6PWS00 Mfr#: 7877-0218
  • Core i5
  • DVD-RW
Enjoy a more productive day with this Zoostorm Delta Elite Desktop PC.
This computer is designed for the constant processing of everyday tasks in busy educational or business environments - for people who like their working lives to run like clockwork. Switch it on and it gets to work in seconds.
The Intel Core i5 processor with 8GB RAM suits those who demand a lot from their PC and gives you the power to handle the unpredictable tasks that arise in a typical working day. Whether you're working on documents, presentations, videos, graphics and images or searching the web for information you need, the PC keeps going all day without the risk of slowing down under the volume of work.
File sharing is made easier thanks to the front-placed USB ports - just slot in a memory stick and transfer what you need. The latest USB 3.0 ports are even faster. A rewritable drive is available for copying and sharing videos.
Windows 10 Professional is designed to make it easier to find apps and files - and to organise your daily working life. This is all made possible by the digital personal assistant service 'Cortana' which you can use to prompt you about meetings, help you find useful websites you want to revisit and locate files when you need to complete tasks more quickly. It gives you added security to protect your information and enables remote log in when you're working away from the office.
A massive 1TB of space on the hard disk allows you to personalise your storage so everything is to hand for the next urgent request.
As a finishing touch, the casing is coated in a scratch resistant paint to withstand tough environments such as the frequent relocation of the workspace.
This PC comes with 3 audio jacks for the times when you need to connect headphones, microphones or speakers.
British made and put through stringent tests, Zoostorm PCs leave our factory only when 100% checked for quality.
Our service includes the support of a UK based telephone helpline.
Zoostorm Delta Elite - Core i5 6400 2.7 GHz - 8 GB - 1 TB
Personal computer - small form factor
1 x Intel Core i5 (6th Gen) 6400 / 2.7 GHz ( 3.3 GHz ) ( Quad-Core )
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
8 GB (installed) / 32 GB (max)
Hard Drive
1 x 1 TB - SATA
Optical Storage
DVD-RW
Graphics Controller
Intel HD Graphics 530
13.2 cm x 32.8 cm x 28.4 cm
3 Year On-site Warranty
Personal computer
Product Form Factor
Small form factor
Processor / Chipset
CPU
Max Turbo Speed
3.3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
8 GB / 32 GB (max)
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA
Optical Storage
DVD-RW
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Bays
1 (total) / 0 (free) x external 5.25"
Slots
1 (total) / 0 (free) x CPU
13.2 cm
32.8 cm
28.4 cm
