Zoostorm Micro Core i5-6400 8GB 120GB SSD Windows 10 Pro
Quicklinx: CF74WS00 Mfr#: 7877-0222
  • Core i5
  • DVD-RW
This Zoostorm Delta Micro Desktop PC is the versatile, reliable choice for busy offices in education and business.
When you need to multi-task in your administrative or business role, this PC will take care of all the everyday tasks you complete using your computer.
The Zoostorm Delta Micro will help you win back time by starting up moments after you arrive at your desk. Because every day starts with demands on your time, you need the PC to get to work quickly. There are calls to be made, emails to be sent and a major events to organise.
The Intel i5 processor and RAM work speedily together to help you handle an ever-growing task list. They won't leave you worrying whether the system might grind to a halt just when you're about to reach an urgent deadline.
Windows 10 Professional is designed to be, virtually, an extra pair of hands. Cortana, your digital personal assistant, can be set up to remind you when urgent meetings are due, to help locate important files and help you find online the sites providing the information you're looking for.
Sharing files with your colleagues has been made easier on this PC. If they need multiple copies you can use some of the USB ports to transfer what they need on to their memory sticks. There are 10 USB connections and 4 of them are the latest high speed transfer ports.
The hard drive gives a practical amount of space to store the files you'll need to hand for your most-frequent tasks.
The DVD-RW drive makes it easy and quick to copy video disks for sharing with your colleagues.
Housed in an ultra-slim, scratch-resistant case, the Zoostorm Delta Micro slots neatly into your workspace and what's more can be fitted to a VESA mount if you want to stay constantly de-cluttered.
Enjoy a more productive working day with the Zoostorm Delta Micro.
British made and put through stringent tests, Zoostorm PCs leave our factory only when 100% checked for quality. Our service includes the support of a UK based telephone helpline.
Zoostorm Delta Micro - Core i5 6400 2.7 GHz - 8 GB - 120 GB
Personal computer - ultra small form factor
1 x Intel Core i5 (6th Gen) 6400 / 2.7 GHz ( 3.3 GHz ) ( Quad-Core )
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
8 GB (installed) / 32 GB (max)
Hard Drive
1 x SSD 120 GB - SATA
Optical Storage
DVD-RW
Graphics Controller
Intel HD Graphics 530
3 Year On-site Warranty
Personal computer
Product Form Factor
Ultra small form factor
Processor / Chipset
CPU
Max Turbo Speed
3.3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
8 GB / 32 GB (max)
Hard Drive
SSD
1 x 120 GB
Interface Type
SATA
Optical Storage
DVD-RW
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Bays
1 external 5.25" , Internal 3.5"
Slots
1 (total) / 0 (free) x CPU
