Zoostorm Micro Core i3-6100 4GB 120GB SSD Windows 10 Pro
Quicklinx: CF72WS00 Mfr#: 7877-0221
  • Core i3
  • DVD-RW
The Zoostorm Delta Micro Desktop PC is designed to help you achieve more in a day.
For schools, offices and in business, this PC is an ideal choice for everyday multi-tasking which needs the assistance of a fast computer.
In environments where space is limited, the PC fits neatly into the work area and helps to keep it de-cluttered.
The moment you arrive at your desk, you're in demand with an ever-growing task list. The Zoostorm Delta Micro is designed to ease your workflow and keep you in control. It starts up in seconds and is sending emails swiftly on their way while you open up presentations and update files in the school portal or business information system.
You won't go short of personal storage with this PC which allows you to keep at your fingertips all your most-used files for the moment you need them.
The processor and RAM are designed for efficiently completing your daily tasks without worrying whether the system might slow down when you're working to an urgent deadline.
Windows 10 Professional (pre-installed) provides Cortana, the digital personal assistant, which you can arrange to have remind you about meetings and help you find information more easily. It provides a level of security essential for the safe operation of any school or company.
Sharing files with your colleagues is made easier by the ports you'll find on the front and rear of the PC. Plug in a USB stick (you have 10 ports) and transfer the files they need. Be sure and use the 3.0 version for a faster transfer. The DVD-RW drive is useful for copying video disks you need to share with your team. Make the most of the ultra-slim design to free up space around your desk and have your PC fitted behind the screen (using a VESA mount).
In a compact case protected by anti-scratch paint, the Delta Micro is everything you need for effortless computing in education and business.
British made and put through stringent tests, Zoostorm PCs leave our factory only when 100% checked for quality. All our customers benefit from the support of a UK based telephone helpline.
Zoostorm Delta Micro - Core i3 6100 3.7 GHz - 4 GB - 120 GB
Personal computer - ultra small form factor
1 x Intel Core i3 (6th Gen) 6100 / 3.7 GHz ( Dual-Core )
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 32 GB (max)
Hard Drive
1 x SSD 120 GB - SATA
Optical Storage
DVD-RW
Graphics Controller
Intel HD Graphics 530
3 Year On-site Warranty
Personal computer
Product Form Factor
Ultra small form factor
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 32 GB (max)
Hard Drive
SSD
1 x 120 GB
Interface Type
SATA
Optical Storage
DVD-RW
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Bays
1 external 5.25" , Internal 3.5"
Slots
1 (total) / 0 (free) x CPU
