Zoostorm Elite Core i3-6100 8GB 120GB SSD Windows 10 Home
Quicklinx: CF6NWS00 Mfr#: 7877-0237
  • Core i3
  • DVD-RW
Multi-tasking and reliable, the Delta Elite Desktop PC will make every workday more productive.
Everyone wants their computer to perform faster, work harder. Designed for constant use in schools and small businesses, this PC is built for busy schedules and for administrators who need more time to complete important and urgent tasks every day. You will get a prompt and responsive start as the computer gets to work in seconds after switching on.
The Intel Core i3 processor and 8GB RAM will help you multi-task with ease through the numerous emails, documents, reports and presentations you have to work on while you search websites, portals and directories for key information.
Because any time-saver is welcome in a busy day, Windows 10 Home comes with Cortana - a digital personal assistant which helps make it easier to locate information in portals, previously visited websites and directories. Set it up to alert you when appointments deadlines are imminent.
For copying, sharing and for attaching printers, storage drives and other devices you'll find 10 USB connections located on the front and back. Use one of the latest USB 3.0 ports when you want a faster data transfer. Videos can be copied for sharing using the rewritable disk.
There is useful personal storage space making all your files instantly available when you need them in a hurry.
With its scratch-resistant painted surface, this PC is protected from damage in heavy-use environments in schools, offices and factories where its durability may be put to the test.
Three audio jacks allow you to connect headphones, microphones or speakers.
British made and put through stringent tests, Zoostorm PCs leave our factory only when 100% passed for quality. Our service includes the support of a UK based telephone helpline.
Zoostorm Delta Elite - Core i3 6100 3.7 GHz - 8 GB - 120 GB
Personal computer - small form factor
1 x Intel Core i3 (6th Gen) 6100 / 3.7 GHz ( Dual-Core )
Cache Memory
3 MB L3 Cache
Cache Per Processor
3 MB
RAM
8 GB (installed) / 32 GB (max)
Hard Drive
1 x SSD 120 GB - SATA
Optical Storage
DVD-RW
Graphics Controller
Intel HD Graphics 530
13.2 cm x 32.8 cm x 28.4 cm
3 Year On-site Warranty
Personal computer
Product Form Factor
Small form factor
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
L3 Cache - 3 MB
Cache Per Processor
3 MB
RAM
Installed Size
8 GB / 32 GB (max)
Hard Drive
SSD
1 x 120 GB
Interface Type
SATA
Optical Storage
DVD-RW
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Bays
1 (total) / 0 (free) x external 5.25"
Slots
1 (total) / 0 (free) x CPU
13.2 cm
32.8 cm
28.4 cm
