Zoostorm Elite Celeron N3050 4GB 500GB Windows 10 Home
Quicklinx: CF6KWS00 Mfr#: 7877-0215
  • Celeron
  • DVD-RW
Finish your work faster with the help of a Zoostorm Delta Elite PC.
For everyday basic computing tasks, this PC is built for constant use in schools, offices and light industrial environments.
The Intel Celeron processor powers up fast to start taking care of the tasks in hand. The 4GB DDR3 memory with 1600MHz RAM keeps the PC working all day on presentations, documents, emails, internet searches and your business or school information portal.
A hard drive of 500 GB storage will comfortably keep thousands of files to hand on the PC. And you can connect other devices for back-ups, sharing and printing using one of the 8 USB ports. Two of the ports are USB3.0 for even faster transfer of information.
The DVD rewritable disk allows you to burn DVDs for sharing videos, photos and files with colleagues.
HD graphics are built-in and the Zoostorm Delta Elite will take a full size graphics card if you’re work involves digital image creation and video editing.
Windows 10 Professional brings you the personal assistant 'Cortana' who can be instructed to remind you of appointments and help you find apps and files. Plus there's added security to safeguard your formation and enable you to log in remotely if you're working away from the office.
The ‘Storm Coat’ scratch-resistant paint protects the surface from the rigours of working life making it ideal for industrial, educational and office environments.
British made and put through stringent tests, Zoostorm PCs leave our factory only when 100% checked for quality.
Our service includes the support of a UK based telephone helpline.
This ‘small form factor’ PC takes up less space and is designed to help you do more in less time.
Zoostorm Delta Elite - Celeron N3050 1.6 GHz - 4 GB - 500 GB
Personal computer - small form factor
1 x Intel Celeron N3050 / 1.6 GHz ( 2.16 GHz ) ( Dual-Core )
Cache Memory
2 MB
Cache Per Processor
2 MB
RAM
4 GB (installed) / 32 GB (max)
Hard Drive
1 x 500 GB - SATA
Optical Storage
DVD-RW
Graphics Controller
Intel HD Graphics 510
13.2 cm x 32.8 cm x 28.4 cm
3 Year On-site Warranty
Personal computer
Product Form Factor
Small form factor
Processor / Chipset
CPU
Max Turbo Speed
2.16 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
2 MB
Cache Per Processor
2 MB
RAM
Installed Size
4 GB / 32 GB (max)
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA
Optical Storage
DVD-RW
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Bays
1 (total) / 0 (free) x external 5.25"
Slots
1 (total) / 0 (free) x CPU
13.2 cm
32.8 cm
28.4 cm
