Zoostorm Brix 7877-0243 Core i5-6200 8GB 256GB SSD Windows 10 Home
Quicklinx: CF6JWS00 Mfr#: 7877-0243
Maximise your Workspace
This Ultra Small Form Factor Mini Desktop PC combines the performance of a fully-equipped desktop PC all packed in to a smaller space saving chassis, with low energy consumption and a large number of practical connections such as USB 2.0 and Wi-Fi.
Windows 10 Home
Windows 10 is familiar and easy to use, with lots of similarities to Windows 7 including the Start menu. It starts up and resumes fast, has more built-in security to help keep you safe and is designed to work with software and hardware that you already have.
Performance and Value you Can Count on
Intel Celeron processors deliver high-performance for everyday computing. Receive performance, serious processing and value with Intel Inside.
Intel HD Graphics – Vibrant Visuals Built In
See your content the way it is meant to be seen—in vibrant, dazzling clarity. Immerse yourself in rich, vivid visuals enabled by integrated Intel HD Graphics.
Intel® Core i5-6200U (6th Generation)
Processor Base Frequency: 2.3GHz (turbo to 2.8GHz)
Cache: 3MB SmartCache
8GB DDR4 2133MHz RAM
Supports up to 32GB
2x So-DIMM sockets (1 used)
Hard Drive
256GB M.2 SSD
Optical Drive
None
Software
Operating System: Windows 10 Home
Microsoft Office not included
Motherboard
Gigabyte Brix
Display
N/A
Graphics
On-board integrated Intel® HD Graphics 520
Audio
Realtek ALC255
Input Devices
Keyboard and Mouse Not Supplied
Dual Band WiFi
Dimensions
Height: 34.4mm
Width: 112.6mm
Depth: 119.4mm
1x HDMI
1x Mini DisplayPort
2 x USB 3.0 Port
1x USB 3.1 type C
1x RJ45 port
2x Audio Jacks
1x Kensington Lock Slot
Expansion
1 x PCI-e M.2 Slot (used)
1x M.2 SSD Slot (used)
Case
USFF Tower Case
Warranty / Miscellaneous
2 Year Return to Base Warranty
Supports up to 32GB
Hard Drive
256GB M.2 SSD
Optical Drive
None
Software
Motherboard
Gigabyte Brix
Display
N/A
Graphics
Audio
Realtek ALC255
Input Devices
Dual Band WiFi
Dimensions
Height: 34.4mm
Width: 112.6mm
Depth: 119.4mm
1x HDMI
1x Mini DisplayPort
2 x USB 3.0 Port
1x USB 3.1 type C
1x RJ45 port
2x Audio Jacks
Expansion
Case
USFF Tower Case
