Product
Zebra ZXP Series 1 Plastic Card Printer
Quicklinx: C6JXWS00 Mfr#: Z11-0000B000EM00
Type: Printer
Functionality: Printer
Wireless Capability: Wired
£700.26 ex VAT
£840.31 inc VAT
The ZXP Series 1 card printer has been designed specifically for customers who need a quality printer at a competitive price. Ideal for low-volume, single-sided printing applications in color or monochrome, the ZXP Series 1 offers a complete card printing solution with a minimal upfront investment. Its Energy Star certification and eco-friendly print cartridges make it the best entrylevel printer on the market.
The ZXP Series 1 requires little technical support or user training. Operation is made simple with intuitive user interface and color touch points. The quick-replace Load-N-Go smart ribbons have the added benefit of being eco-friendly, using less plastic and more biodegradable material. Print touch uses near field communication (NFC) to instantly retrieve helpful information about the ZXP Series 1 from any NCF-enabled smart device.
A small footprint allows the ZXP Series 1 to fit in the tightest workspaces, making it the right choice when space is limited. Its compact and durable design and advanced network printer management software tools, make the ZXP Series 1 a perfect for multiple small office installations, or large deployments of distributed card printers.
You can count on the ZXP Series 1 to print clear, sharp and color rich images when you need them, and where you need them. Its optional magnetic stripe encoding, Ethernet connectivity, and support for multiple card thicknesses permit the ZXP Series 1 to meet a variety of business and ID card needs.
  • Affordable, entry-level printer
  • Ease of use
  • Compact size and network manageable
  • No compromise high quality cards
Zebra ZXP Series 1 - plastic card printer - colour - dye sublimation
Printer Type
Plastic card printer - dye sublimation - colour
5.3 kg
United Kingdom, Europe
Max Media Size
CR-80 Card (85.6 x 54 mm)
Max Media Size (Custom)
85.6 mm x 54 mm
Print Speed
Up to 500 cards/hour - monochrome - CR-80 Card (85.6 x 54 mm) , Up to 120 cards/hour - colour single-sided - CR-80 Card (85.6 x 54 mm)
Max Resolution (B&W)
300 dpi
USB 2.0
Media Type
Cards, PVC composite card, PVC card
Total Media Capacity
100 cards
Printer Features
Zebra ZRaster technology
AC 120/230 V
Microsoft Certification
Compatible with Windows 7
2 years warranty
20 cm x 33 cm x 23.6 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB 2.0
300 dpi
Printer Features
Media Handling
Media Type
Max Media Size
85.6 mm x 54 mm
Card / Label Sizes
100 cards
Media Feeders
1 x automatic - 100 cards - CR-80 Card (85.6 x 54 mm)
Max Media Capacity
100 cards
Output Trays Capacity
45 cards
1 x USB 2.0 - 4 pin USB Type B
Cleaning kit, web camera
1 x USB cable
Consumables Included
1 x ribbon (yellow/cyan/magenta/black/overcoat)
Media Included
100 PVC cards
FCC Class A certified, ISO 7811, ISO 7810
AC 120/230 V
Frequency Required
50/60 Hz
Software Included
Drivers & Utilities, Zebra ZMotif CardStudio Standard
Environmental Standards
ENERGY STAR
Limited warranty - 2 years , Limited warranty - printhead - 2 years
15 °C
30 °C
20 - 65% (non-condensing)
20 cm
33 cm
23.6 cm
5.3 kg
Type: Printer
Brand: Zebra
Price Range Ex VAT: 500 - 750
