Zebra ZT420 Monochrome Direct Thermal Label Printer
Quicklinx: BJ1ZWS00 Mfr#: ZT42063-T0E0000Z
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired, Wireless
Technology: Direct thermal / thermal transfer
£1,850.01 ex VAT
£2,220.01 inc VAT
Keep your critical operations running efficiently with Zebra's durable ZT400 Series printer, designed for years of performance in a wide array of applications.
The ZT400 Series builds on the field-proven reliability of the Z Series with advancements in print speed, print quality and connectivity options. Designed for ease of use, the ZT400 Series printers offer an intuitive iconbased LCD graphical user interface and easy supplies loading. And, they include standard USB, Serial, Ethernet and Bluetooth capabilities. Expanded RFID capacities deliver greater tracking abilities, deeper visibility and enterprise insights.
Designed to grow with your evolving business needs. The ZT400 features increased processing capabilities and an open operating architecture providing flexibility to support your ever-growing and changing application requirements.
Zebra ZT400 Series ZT420 - label printer - B/W - direct thermal / thermal transfer
Printer Type
Label printer - direct thermal / thermal transfer - B/W
18.14 kg
United Kingdom, Europe
Max Media Size
Roll (17.8 cm)
Min Media Size (Custom)
51 mm
Max Media Size (Custom)
178 mm x 991 mm
Print Speed
Up to 254 mm/sec
Max Resolution (B&W)
300 dpi
USB 2.0, LAN, serial, USB host, Bluetooth 2.1
RAM Installed (Max)
256 MB
Flash Memory Installed (Max)
512 MB
Language Simulation
ZPL, ZPL II, EPL, Extensible Mark-up Language (XML)
Barcodes
Code 93, Industrial 2 of 5, Code 39, Code 49, CODABLOCK, ISBT 128, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 11, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, PLANET, TLC39, Plessey, Code 128B, Code 128C, Code 128A, Standard 2 of 5
Media Type
Continuous paper labels, die cut labels
Realtime clock, transmissive media sensor, reflective media sensor, tear bar
Print server
AC 120/230 V
Microsoft Certification
Compatible with Windows 7
33.655 cm x 49.5 cm x 32.4 cm
Printer Type
Label printer - direct thermal / thermal transfer - monochrome
Printer
Print Speed
Up to 254 mm/sec
Built-in Devices
Status LCD, tear bar
Wireless
300 dpi
Language Simulation
Fonts Included
1 x barcode , 16 x bitmapped , 2 x scalable
Barcodes
RAM
RAM Installed (Max)
256 MB
Flash Memory
Flash Memory
512 MB
Media Handling
Media Type
Max Media Size
Roll (17.8 cm)
51 mm
178 mm x 991 mm
Media Sizes
Roll (5.1 - 17.8 cm)
Max Printing Width
168 mm
Max Printing Length
1143 mm
Media Thickness Range
0.058 mm - 0.25 mm
Roll Maximum Outer Diameter
203 mm
Roll Core Diameter
76 mm
Media Feeders
1 x manual - 1 roll - Roll (17.8 cm)
Print server
1 x RS-232 , 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
FCC Class B certified, VCCI, C-Tick, BSMI, EN 61000-3-2, ICES-003, NOM, SABS, IEC 60950, EN 61000-3-3, EN55024, EN55022 Class B, CCC, KCC, S Mark, cTUVus
Power supply - internal
AC 120/230 V
Frequency Required
50/60 Hz
Power Factor Correction
Environmental Standards
ENERGY STAR
5 °C
20 - 85% (non-condensing)
33.655 cm
49.5 cm
32.4 cm
18.14 kg
BJ1Z Zebra ZT420 Kit Platen Roller In Stock £61.69
Type: Printer
Wireless Capability: Wireless
Max Print Speed: [N/A]
Max Paper Size: Roll (17.8 cm)
Brand: Zebra
Price Range Ex VAT: £1500+
