Keep your critical operations running efficiently with Zebra's durable ZT400 Series printer, designed for years of performance in a wide array of applications.
The ZT400 Series builds on the field-proven reliability of the Z Series with advancements in print speed, print quality and connectivity options. Designed for ease of use, the ZT400 Series printers offer an intuitive iconbased LCD graphical user interface and easy supplies loading. And, they include standard USB, Serial, Ethernet and Bluetooth capabilities. Expanded RFID capacities deliver greater tracking abilities, deeper visibility and enterprise insights.
Designed to grow with your evolving business needs. The ZT400 features increased processing capabilities and an open operating architecture providing flexibility to support your ever-growing and changing application requirements.
Easy to integrate and manage
ZT400 Series printers are easy to integrate, manage and maintain from any location around the globe. -
ZT400 Series printers feature increased processing capabilities and an open operating architecture providing flexibility to support your evergrowing and changing application requirements. -
Cloud technology
Featuring the Link-OS Cloud Connect application, these printers can connect to the Cloud directly and securely, forwarding data from any port.
- Zebra ZT410 - label printer - B/W - direct thermal / thermal transfer
- Printer Type
- Label printer - direct thermal / thermal transfer - B/W
- 16.33 kg
- Localisation
- United Kingdom, Europe
- Max Media Size
- Roll (10.8cm)
- Min Media Size (Custom)
- 25.4 mm
- Max Media Size (Custom)
- 108 mm x 991 mm
- Print Speed
- Up to 356 mm/sec - max speed
- Max Resolution (B&W)
- 203 dpi
- Interface
- USB 2.0, LAN, serial, USB host, Bluetooth 2.1
- RAM Installed (Max)
- 256 MB
- Flash Memory Installed (Max)
- 512 MB
- Language Simulation
- ZPL, ZPL II, EPL, Extensible Mark-up Language (XML)
- Barcodes
- Code 93, Industrial 2 of 5, Code 39, Code 49, CODABLOCK, ISBT 128, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 11, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, PLANET, TLC39, Plessey, Code 128B, Code 128C, Code 128A, Standard 2 of 5
- Media Type
- Continuous paper labels, die cut labels
- Rewinder, realtime clock
- Networking
- Print server
- Microsoft Certification
- Compatible with Windows 7
- 26.9 cm x 49.5 cm x 32.4 cm
- Printer Type
- Label printer - direct thermal / thermal transfer - monochrome
- Localisation
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wireless
- Interface
- 203 dpi
- Fonts Included
- 16 x bitmapped , 2 x scalable
- Barcodes
RAM
- 256 MB
Flash Memory
- Flash Memory
- 512 MB
Media Handling
- Media Type
- Max Media Size
- Roll (10.8cm)
- 25.4 mm
- 108 mm x 991 mm
- Media Sizes
- Roll (2.54 - 10.8 cm)
- Max Printing Width
- 104 mm
- Max Printing Length
- 3988 mm
- Media Thickness Range
- 0.058 mm - 0.25 mm
- Roll Maximum Outer Diameter
- 203 mm
- Roll Core Diameter
- 76 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (10.8cm)
- Networking
- Print server
- Connections
- 1 x RS-232 , 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Included Accessories
- Rewind
- Paper sensor
- FCC Class B certified, VCCI, C-Tick, BSMI, EN 61000-3-2, ICES-003, NOM, SABS, IEC 60950, EN 61000-3-3, EN55024, EN55022 Class B, CCC, KCC, S Mark, cTUVus
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- Power Factor Correction
Environmental Standards
- ENERGY STAR
- 5 °C
- 40 °C
- 20 - 85% (non-condensing)
- 26.9 cm
- 49.5 cm
- 32.4 cm
- 16.33 kg
