Zebra's smallest and most affordable mobile receipt printer, the ZQ110 is compact and lightweight enough to fit in a pocket or wear comfortably on a belt for an entire shift. Quickly print and tear 50mmwide receipts, tickets and delivery notices on site, saving time and money - all while improving customer service.
Easy to carry and simple to use, the ZQ110 offers intuitive media loading for quick, on-the-go media changes. Its straightforward user interface enables at-a-glance status updates. Plus, with a battery capable of lasting an entire shift and multiple charging options, users experience greater uptime and increased productivity with fewer printing interruptions.
- Zebra ZQ110 - receipt printer - monochrome - direct thermal
- Printer Type
- Receipt printer - direct thermal - monochrome
- Form Factor
- Portable
- 229 g
- Max Media Size
- Roll (5.8 cm)
- Max Media Size (Custom)
- 58 mm
- Print Speed
- Up to 90 mm/sec - B/W
- Max Resolution (B&W)
- 203 dpi
- Interface
- USB 2.0, Bluetooth 3.0 EDR
- Flash Memory Installed (Max)
- 4 MB
- Language Simulation
- EPSON ESC/POS
- Barcodes
- Code 93, Code 39, QR code, Aztec code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, PDF417, Data Matrix, ITF
- Media Type
- Receipt paper, linerless labels, tickets
- Tear bar
- Networking
- Print server
- Battery
- Required 1 Lithium Ion Included Qty 1
- System Requirements
- Microsoft Windows Mobile, Android, Apple iOS
- 8.01 cm x 11.88 cm x 3.77 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Magnetic Stripe Reader, tear bar
- Connectivity Technology
- Wireless
- Interface
- 203 dpi
- EPSON ESC/POS
- Tear bar
- Barcodes
Flash Memory
- Flash Memory
- 4 MB
Media Handling
- Media Type
- Max Media Size
- Roll (5.8 cm)
- 58 mm
- Media Sizes
- Roll (5.8 cm)
- Max Printing Width
- 48 mm
- Media Thickness Range
- 0.06 mm - 0.1 mm
- Roll Maximum Outer Diameter
- 30 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (5.8 cm)
- Networking
- Print server
- Connections
- 1 x USB 2.0
- Included Accessories
- Belt clip
- Water-resistant, dust-resistant
- UL, BSMI, NOM, EN55024, EN55022 Class B, CB, FCC Part 15 B, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, CCC, EN 61000-4-5, KCC, ANATEL, IP54, MFI, iDA, RCM, BIS
- Power Device
- Power adapter - external
- Lithium Ion
- Required Qty
- 1
- Included
- 1
- Capacity
- 1200 mAh
- OS Required
- -15 °C
- 50 °C
- 10 - 80% (non-condensing)
- 8.01 cm
- 11.88 cm
- 3.77 cm
- 229 g
