Z-Perform 1000D is an uncoated direct thermal paper facestock that offers a low-cost solution for general-purpose industrial applications up to 3 inches per second. With its permanent acrylic adhesive and consistent quality, it is an excellent option for compliance labeling, product labeling, shelf labeling, and work-in-process labeling and is recommended for short-term applications that do not require durability against moisture or tough environmental conditions including heat, humidity, or U.V. light.
- Zebra Z-Perform 1000D - labels - 21480 label(s) - 102 x 38 mm
- Product Type
- Labels
- Product Material
- Paper
- Adhesive Type
- Permanent adhesive
- Coating
- Uncoated
- Media Size
- 102 x 38 mm
- Printing Technology
- Direct thermal
- Card / Label Qty per Sheet/Roll
- 1790
- Qty of Media with Cards
- 12 roll(s)
- Included Qty
- 21480 label(s)
- Compatible with
- LP 2824; TLP 2824, 2844; Zebra GX420d, GX420t; GK Series GK420t; G-Series GC420t; GX Series GX420, GX430, GX430t; LP 2824, 2824 Plus, 2824-Z, 2844, 2844-Z; TLP 2824, 2824 Plus, 2824-Z, 2844, 2844-Z, 3842, 3844-Z
Media
- Media Type
- Labels
- Product Material
- Paper
- Adhesive Type
- Coating
- Uncoated
- Media Sizes
- 102 x 38 mm
- Direct thermal
- Roll Maximum Outer Diameter
- 127 mm
- Roll Core Diameter
- 25 mm
- 1790
- 12 roll(s)
- Included Qty
- 21480 label(s)
- Compatible with
- Eltron LP 2824 , Eltron TLP 2824, 2844 , Zebra GX420d, GX420t , Zebra GK Series GK420t , Zebra G-Series GC420t , Zebra GX Series GX420, GX430, GX430t , Zebra LP 2824, 2824 Plus, 2824-Z, 2844, 2844-Z , Zebra TLP 2824, 2824 Plus, 2824-Z, 2844, 2844-Z, 3842, 3844-Z
