Zebra Xi Series 170Xi4 Wireless Label Printer 170XI4 300DPI RWD
Quicklinx: CKDNWS00 Mfr#: 170-80E-00203
The industrial-strength 170Xi4 can print large volumes of labels, promoting greater productivity with fewer roll changes. Or it can execute intricate, high-resolution print applications at a quick 8" per second. With its all-metal construction, this printer is ideal for tough applications including compliance labels, product identification labels, and pallet shipping/receiving labels, either on demand or in batches.
Zebra Xi Series 170Xi4 - label printer - B/W - thermal transfer
Printer Type
Label printer - thermal transfer - B/W
30.5 kg
Max Media Size
Roll (20.3 cm)
Max Media Size (Custom)
168 mm x 3810 mm
Max Resolution (B&W)
300 dpi
Image Enhancement Technology
Multi-level Element Energy Equalizer
Parallel, USB, LAN, serial
133 MHz
RAM Installed (Max)
16 MB SDRAM
Flash Memory Installed (Max)
8 MB
Language Simulation
ZPL II, Extensible Mark-up Language (XML)
Barcodes
Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, CODABLOCK, ISBT 128, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Code 2 of 5, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, PLANET, TLC39, Code 128B, Code 128C, Code 128A
Media Type
Labels, continuous forms, fanfold paper
Total Media Capacity
1 roll
Print server - Ethernet, Fast Ethernet
Microsoft Certification
Compatible with Windows 7
33.8 cm x 51.8 cm x 39.4 cm
Printer Type
Label printer - thermal transfer - monochrome
Printer
Built-in Devices
Status LCD
Wired
300 dpi
Language Simulation
Fonts Included
1 x bitmapped , 1 x scalable
Barcodes
133 MHz
RAM
RAM Installed (Max)
16 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
8 MB
Media Handling
Media Type
Max Media Size
Roll (20.3 cm)
168 mm x 3810 mm
Media Sizes
Roll (20.3 cm)
Media Thickness Range
0.76 mm - 0.305 mm
Roll Maximum Outer Diameter
203 mm
Roll Core Diameter
76 mm
1 roll
Media Feeders
1 x manual - 1 roll - Roll (20.3 cm)
Print server
Network Controller Name
ZebraNet 10/100 Print Server
Expansion Slots
1 x parallel - 36 PIN Centronics , 1 x RS-232/422/485 , 1 x USB , 1 x LAN - RJ-45
Peeler, rewind
Paper sensor
FCC Class B certified, VCCI, C-Tick, BSMI, EN 60950, EN 61000-3-2, NOM, EN 61000-3-3, EN55024, EN55022 Class B, ICES-003 Class B, CCC, IEC 60950-1, KCC, GOST-R, S Mark, cTUVus
Power supply - internal
Frequency Required
50/60 Hz
Software Included
Drivers & Utilities
5 °C
20 - 85%
33.8 cm
51.8 cm
39.4 cm
30.5 kg
