The MC9200 rugged mobile computer, the next generation of the industry-leading gold standard for mobility, has evolved to meet changing business needs, bringing you the same signature rugged design, best-in-class barcode scanning and dependable operation. Now, with the power to run applications with highly-intuitive interfaces, the MC9200 will further simplify processes and increase worker productivity in your toughest environments.
The power you need to support any application
A dual core 1 GHz processor, 2GB of Flash memory, up to 32GB of additional SD memory and Microsoft's advanced mobile operating systems provide provide the power to run complex ERP applications — simultaneously.
High-speed 802.11a/b/g/n Wi-Fi
Support for the fastest Wi-Fi connection available today — 802.11n — provides your workers with the best possible wireless voice and data experience.
Proven rugged construction, ready for your most challenging environments
Every day, the MC9000 Series devices deliver reliable performance, despite everyday drops on concrete, subzero cold, extreme heat, dust, spills and more.
Government-grade security
Government-grade FIPS 140-2 Level 1 certification secures Wi-Fi and Bluetooth wireless communications, without impacting device or application performance.
Six advanced scan engines — the most scan engine options
No matter what type of bar codes are in use in your facility, there is a scan engine option that is optimized for rapid-fire capture of 1D, 2D, driver’s license, DPM codes and more — even if the codes are dirty, damaged or poorly printed.
Six interchangeable keypads for superior customization
Choose the keypad that makes data entry as easy as possible for any type of application.
Every day, the MC9200 Series devices deliver reliable performance, despite everyday drops on concrete, subzero cold, extreme heat, dust, spills and more. -
Government-grade FIPS 140-2 Level 1 certification secures Wi-Fi and Bluetooth wireless communications, without impacting device or application performance. -
- Zebra MC92N0-G - data collection terminal - Win Embedded Compact 7 - 2 GB - 3.7"
- Product Type
- Data collection terminal - rugged
- Operating System
- Microsoft Windows Embedded Compact 7
- Display
- 3.7" colour TFT - 640 x 480
- Processor
- OMAP4430 OMAP4430 (Dual-Core)
- Processor Clock Speed
- 1 GHz
- Storage
- 2 GB
- RAM
- 512 MB
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card
- Wireless Connectivity
- 802.11a/b/g/n, Bluetooth 2.1 EDR
- Barcode Reader
- Yes (laser)
- 9.1 cm x 19.3 cm x 23.1 cm
- 765 g
- 1-year warranty
- Product Type
- Operating System
Display
- 3.7" colour TFT
- Resolution
- 640 x 480
- Colour Depth
- 64K colours (16-bit)
- Processor
- OMAP4430 OMAP4430
- 1 GHz
- Number of Cores
- Dual-Core
- Storage
- 2 GB
- RAM
- 512 MB
- Max Supported Capacity
- 32 GB
Communications
- LEAP, TLS, WPA2, 802.1x, AES
Multimedia
- Audio
- Microphone, speaker
Input Device
- Touch-screen, keypad
- Keys Qty
- 28
Barcodes
- Barcode Reader
- Scan Element Type
- Laser
Expansion and Connectivity
- Expansion Slots
- 1 x SDHC Memory Card
- Technology
- Lithium Ion
- Capacity
- 2200 mAh
- Included Accessories
- Pistol grip handle
- EN55024, EN55022 Class B, ICES-003 Class B, FCC Part 15.247, OET 65 C, RSS-210, RSS-102, FCC Part 15, RoHS, FIPS 140-2, FCC Part 2, UL 60950-1, IEC 60950-1, EN 60950-1, MIL-STD 810G, IEC 60825-1, FCC Part 15.407, CCX V4, EN 50371, CSA C22.2 No. 60950-1, EN 60825-1, IEC 60529 IP64, EN 62311, EN 300 328, EN 301 489-1, EN 301 893, EN 301 489-17
- 9.1 cm
- 19.3 cm
- 23.1 cm
- 765 g
- Limited warranty - 1 year
- -20 °C
- 50 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
Zebra MC9X 2600 Mah Lithium Ion Handheld Battery | In Stock | £64.44 |
