Zebra MC9200 Data Collection Terminal 2GB 3.7" - Win Mobile 6.5
Quicklinx: DJZMWS00 Mfr#: MC92N0-GL0SXERA5WR
40 in stock
£1,565.30 ex VAT
£1,878.36 inc VAT
The MC9200 rugged mobile computer, the next generation of the industry-leading gold standard for mobility, has evolved to meet changing business needs, bringing you the same signature rugged design, best-in-class barcode scanning and dependable operation. Now, with the power to run applications with highly-intuitive interfaces, the MC9200 will further simplify processes and increase worker productivity in your toughest environments.
  • The power you need to support any application
    A dual core 1 GHz processor, 2GB of Flash memory, up to 32GB of additional SD memory and Microsoft's advanced mobile operating systems provide the power to run complex ERP applications - simultaneously.
  • High-speed 802.11a/b/g/n Wi-Fi
    Support for Wi-Fi connection available today provides your workers with wireless voice and data experience.
  • Proven rugged construction, ready for your most challenging environments
    Every day, the MC9000 Series devices deliver reliable performance, despite everyday drops on concrete, subzero cold, extreme heat, dust, spills and more.
  • Government-grade security
    Government-grade FIPS 140-2 Level 1 certification secures Wi-Fi and Bluetooth wireless communications, without impacting device or application performance.
  • Six advanced scan engines
    No matter what type of barcodes are in use in your facility, there is a scan engine option that is optimized for rapid-fire capture of 1-D, 2-D, driver's license, DPM codes and more - even if the codes are dirty, damaged or poorly printed.
  • Six interchangeable keypads for superior customization
    Choose the keypad that makes data entry as easy as possible for any type of application.
Zebra MC9200 - data collection terminal - Win Mobile 6.5 - 2 GB - 3.7"
Data collection terminal - rugged
Operating System
Microsoft Windows Mobile 6.5
Display
3.7" colour - 640 x 480
Texas Instruments OMAP 4 (Dual-Core)
Processor Clock Speed
1 GHz
Storage
2 GB
RAM
512 MB
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card
Wireless Connectivity
802.11a/b/g/n, Bluetooth 2.1 EDR
Barcode Reader
Yes (2D imager)
PowerPrecision
9.1 cm x 23.1 cm x 19.3 cm
765 g
Operating System
Display
3.7" colour
Resolution
640 x 480
1 GHz
Number of Cores
Dual-Core
Storage
2 GB
RAM
512 MB
Max Supported Capacity
32 GB
Communications
Security Protocols & Features
LEAP, 802.1x, AES, TTLS, EAP-TLS, PEAP, EAP-FAST, CCXv4, WPA2-Enterprise
Multimedia
Audio
Microphone, speaker
Input Device
Alphanumeric keyboard
Keys Qty
53
Barcodes
Barcode Reader
Scan Element Type
2D imager
Expansion and Connectivity
Expansion Slots
1 x SD Memory Card
1 x headset sub-mini jack (2.5mm)
PowerPrecision - Lithium Ion
2400 mAh
Condensation-resistant, Gun Form Factor, SE4750SR Imager
RoHS, MIL-STD 810G, IP64
9.1 cm
23.1 cm
19.3 cm
765 g
-20 °C
50 °C
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Brand: Zebra
Price Range Ex VAT: 1500+
