The MC9200 rugged mobile computer, the next generation of the industry-leading gold standard for mobility, has evolved to meet changing business needs, bringing you the same signature rugged design, best-in-class barcode scanning and dependable operation. Now, with the power to run applications with highly-intuitive interfaces, the MC9200 will further simplify processes and increase worker productivity in your toughest environments.
The power you need to support any application
A dual core 1 GHz processor, 2GB of Flash memory, up to 32GB of additional SD memory and Microsoft's advanced mobile operating systems provide the power to run complex ERP applications - simultaneously. -
High-speed 802.11a/b/g/n Wi-Fi
Support for Wi-Fi connection available today provides your workers with wireless voice and data experience. -
Proven rugged construction, ready for your most challenging environments
Every day, the MC9000 Series devices deliver reliable performance, despite everyday drops on concrete, subzero cold, extreme heat, dust, spills and more. -
Government-grade security
Government-grade FIPS 140-2 Level 1 certification secures Wi-Fi and Bluetooth wireless communications, without impacting device or application performance. -
Six advanced scan engines
No matter what type of barcodes are in use in your facility, there is a scan engine option that is optimized for rapid-fire capture of 1-D, 2-D, driver's license, DPM codes and more - even if the codes are dirty, damaged or poorly printed. -
Six interchangeable keypads for superior customization
Choose the keypad that makes data entry as easy as possible for any type of application.
- Zebra MC9200 - data collection terminal - Win Mobile 6.5 - 2 GB - 3.7"
- Product Type
- Data collection terminal - rugged
- Operating System
- Microsoft Windows Mobile 6.5
- Display
- 3.7" colour - 640 x 480
- Processor
- Texas Instruments OMAP 4 (Dual-Core)
- Processor Clock Speed
- 1 GHz
- Storage
- 2 GB
- RAM
- 512 MB
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card
- Wireless Connectivity
- 802.11a/b/g/n, Bluetooth 2.1 EDR
- Barcode Reader
- Yes (2D imager)
- Battery
- PowerPrecision
- 9.1 cm x 23.1 cm x 19.3 cm
- 765 g
- Product Type
- Operating System
Display
- 3.7" colour
- Resolution
- 640 x 480
- Processor
- 1 GHz
- Number of Cores
- Dual-Core
- Storage
- 2 GB
- RAM
- 512 MB
- Max Supported Capacity
- 32 GB
Communications
- LEAP, 802.1x, AES, TTLS, EAP-TLS, PEAP, EAP-FAST, CCXv4, WPA2-Enterprise
Multimedia
- Audio
- Microphone, speaker
Input Device
- Alphanumeric keyboard
- Keys Qty
- 53
Barcodes
- Barcode Reader
- Scan Element Type
- 2D imager
Expansion and Connectivity
- Expansion Slots
- 1 x SD Memory Card
- 1 x headset sub-mini jack (2.5mm)
- Technology
- PowerPrecision - Lithium Ion
- Capacity
- 2400 mAh
- Condensation-resistant, Gun Form Factor, SE4750SR Imager
- RoHS, MIL-STD 810G, IP64
- 9.1 cm
- 23.1 cm
- 19.3 cm
- 765 g
- -20 °C
- 50 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
Zebra MC9X 2600 Mah Lithium Ion Handheld Battery | In Stock | £64.09 |
