Product
Zebra MC55 LP 1D CAM VGA QTY
Need a Mobile Tariff ??? See Description Below
Quicklinx: 7Z2SWS00 Mfr#: MC55A0-P90SWQQA9WR
Give managers and task workers everything they need to take instant action anywhere. Pure business on the inside and smart styling on the outside, the MC55A0 rugged mobile computer for enterprise lets your workers access business applications, scan barcodes, snap a photo, view a video and place a private or push-to-talk call to virtually anyone in your facility – all with a single device. The sleek lightweight design is not only pocketable, it is at home in front of customers and patients. And government grade FIPS 140-2 security keeps your most sensitive data safe and secure.
  • Powerful microprocessor designed for mobility
    The Marvell PXA320 @ 806 MHz provides best-in-class application performance coupled with ubiquitous mobility inside the enterprise even on the most demanding multi-media applications.
  • The memory to support any application
    256MB RAM/1GB Flash and a user accessible microSD card slot with support up to 32GB provide the memory space required to enable robust performance for database and other processing intensive applications.
  • The most advanced mobile operating system for the enterprise
    Microsoft's Windows 6.5 Mobile Edition increases interoperability with existing enterprise infrastructure; enhances security features; provides a more flexible development platform; improves mobile messaging collaboration.
  • Protects your application investments
    Support for Enterprise Mobility Developer Kit (EMDK) APIs preserves existing application investments by enabling easy and cost-effective porting of applications from other Zebra mobile computers.
  • Works on virtually any wireless LAN
    The 802.11a/b/g tri-mode radio connects to both 2.4GHz and 5GHz WLANs for cost-effective voice and data connectivity in the office and hot spots; 802.11a (5GHz band) support enables segmentation of voice traffic to ensure voice quality.
  • The most advanced Bluetooth functionality
    Bluetooth v2.1 with EDR provides a wireless connection to more device types, including modems, printers, headsets and more; simplifies pairing; improves security; reduces power consumption; supports either Microsoft or Stonestreet stacks.
  • Government grade security over virtually any WLAN
    Make sure only authorized users access your devices, your data and your network. Bring wired-line security to your wireless communications without impacting wireless performance through a multitude of security features, including: native FIPS 140-2 Level 1 certification; support for all the latest encryption and authentication protocols; compatibility with Mobile Security Suite for device-level protection (device level firewall, intrusion prevention, enforced authentication, data encryption and integrity monitoring protect the data that is resident on and in transit to and from your MC55A0 devices); and compatibility with Zebra Mobile Virtual Private Networks (MVPNs).
  • Business class motion sensing for the intelligence to sense - and act - on motion
    Automatically rotates screen to match; device orientation automatically reverts to sleep mode when not in use to preserve battery power; landscape mode improves the display of data-intensive applications; enables utilization of sensor data in custom applications.
  • Advanced sleek design for ease of use and user comfort
    Specifically designed for one-handed operation - data entry is easy regardless of hand size with minimal movement.
Motorola MC55A0 - Enterprise - data collection terminal - Win Mobile 6.5 Classic - 1 GB - 3.5"
Data collection terminal - rugged
Operating System
Microsoft Windows Mobile 6.5 Classic
Display
3.5" colour LED backlight - 640 x 480
Marvell XScale PXA320
Processor Clock Speed
806 MHz
Storage
1 GB
RAM
256 MB
Supported Flash Memory Cards
microSD, microSDHC
Wireless Connectivity
802.11a/b/g, Bluetooth 2.1 EDR
Camera
3.2 Megapixel (rear)
Barcode Reader
Yes (laser)
Extended capacity battery
7.7 cm x 2.7 cm x 14.7 cm
315 g
1 year warranty
Operating System
Display
3.5" colour - LED backlight
Resolution
640 x 480
806 MHz
Storage
1 GB
RAM
256 MB
microSD, microSDHC
Max Supported Capacity
32 GB
Communications
Security Protocols & Features
LEAP, WEP, TLS, WPA2, TKIP
Camera
Resolution (MP)
Multimedia
Audio
Microphone, speaker
Input Device
Touch-screen, QWERTY keyboard
Barcodes
Barcode Reader
Scan Element Type
Laser
Minimum Bar Width
0.127 mm
Expansion and Connectivity
Expansion Slots
1 x microSD
1 x USB
Extended capacity battery - Lithium Ion
3600 mAh
Sensors
Accelerometer
LED indicator
cUL, EN55022 Class B, ICES-003 Class B, EN 300.328, EN 301.489.1, EN 301.489.17, FCC Part 15 B, FCC Part 15.247, OET 65 C, RSS-210, RSS-102, RoHS, FIPS 140-2, FCC Part 2, UL 60950-1, EN 60950-1, AS/NZS 4268, MIL-STD 810G, RSS-310, EN 300.440.2, IP64, EN 301.893, IEC 60825-1, FCC Part 15.407, EN 60601-1-2, ARIB STD-T66, ARIB STD-T70, ARIB STD-T71, ARIB STD-T33, CCX V4, EN 301.489.19, EN 60825-1, EN 50392
7.7 cm
2.7 cm
14.7 cm
315 g
Limited warranty - 1 year
-10 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
