Zebra LS2208 Handheld USB Scanner
Quicklinx: 5862WS00 Mfr#: LS2208-SR20007R-UR
Type: Barcode scanner
Form Factor: Handheld
Max Paper Size: [N/A]
Compatibility: PC
More than 50 in stock
£59.73 ex VAT
£71.67 inc VAT
Symbol LS2208 Handheld USB Laser Barcode Scanner
  • General Features:
  • 7-footUSB cable
  • USE interface
  • Durable scan element design
  • Fast performance at 100 scans per second
  • Global Trade Item Number (GTlN) Compliant
  • Advanced Data Formatting (ADF) enables users to modify data prior to sending to host computer
  • Universal cables for sharing
  • Bright LED and beeper with adjustable volume
  • Ergonomic design
  • Bi-directional scanner
  • 650 nm visible laser diode light source
  • Durable single-board construction
    Meets stringent 5-ft drop tests.
  • Scratch-resistant tempered glass exit window
    Is designed for continuous use.
  • Accurate first-time capture of 1D bar codes
    Increased productivity, resulting in shorter check-out lines and better customer service.
  • Wide working range
    Delivers optimal performance from contact to 17 in (43 cm).
  • Multiple on-board interfaces
    Simplify installation and integration and ensures future compatibility.
  • Plug-and-play, with universal cable
    Means rapid deployment, with a single cable connecting to any computing environment.
  • Intuitive design
    Minimizes setup and training time.
  • Ergonomic, lightweight design
    Reduces user fatigue with sleek, balanced form for maximum comfort and productivity.
  • Hands-free Intellistand
    Enables presentation scanning and easy switching between hands-free and handheld modes.
    Enables users to modify data prior to sending to host computer, reducing costly modifications to the host software.
Symbol LS2208 - barcode scanner
Barcode scanner - handheld - USB - decoded
Twilight black
Scan Element Type
Visible laser diode
Scan Speed
100 scan / sec
Wired
6.3 cm x 8.4 cm x 15.2 cm
146 g
5-year warranty
Twilight black
Barcode
Interface Type
USB
Scan Element Type
Visible laser diode
Light Source Wave Length
650 nm
Scan Mode
Single-pass
Scan Speed
100 scan / sec
Max Working Distance
43 cm
Skew (Degrees)
60
Pitch (Degrees)
65
Print Contrast Signal (PCS)
20%
Decode Capability
EAN/JAN, Code 93, Code 39, UCC/EAN-128, IATA, GS1 DataBar, Code 39 Full ASCII, Discrete 2 of 5, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, MSI-Plessey, Code 128 Full ASCII
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator
1 x USB - Type A
Stand
1 x USB cable - external
VCCI, EN 60950, UL 1950, CSA 22.2 No. 950, ICES-003 Class B, FCC Part 15 B, MITI, EMC, RoHS, IEC 950
6.3 cm
8.4 cm
15.2 cm
146 g
Limited warranty - 5 years
50 °C
5 - 95%
Drop Specification
1.5 m to concrete
Compatibility: PC
Brand: Zebra
Price Range Ex VAT: 50 - 100
