Zebra Motorola LI4278 Bluetooth Barcode scanner
Quicklinx: 80LTWS00 Mfr#: LI4278-TRWU0100ZER
Type: Barcode scanner
Form Factor: Portable
Max Paper Size: [N/A]
Compatibility: PC
£213.92 ex VAT
£256.70 inc VAT
The LI4278 takes 1-D barcode scanning to the next level, allowing workers to scan faster and farther as they can capture virtually any 1-D barcode. Built for all day and everyday use, the LI4278 offers cordless freedom with Bluetooth compatibility. It also offers better encryption for improved security and better overall wireless performance.
Superior battery power management delivers the largest number of scans per battery charge to support scan intensive applications. You can use it in dusty and wet environments and it can survive a 6 foot/1.8 m drop.
  • Excellent 1-D scanning performance
    Delivers superior scanning speed and a wide data capture range.
  • Captures virtually all 1-D barcodes on any surface - including mobile phone displays
    Capture labels printed on traditional paper labels as well as mobile barcodes that may be displayed on a mobile phone, tablet or computer screen.
  • Wide working range
    Reads UPC barcodes from 1 in./2.54 cm to 30 in./76.2 cm as well as high density codes at extended ranges for application flexibility.
  • Superior motion and angular tolerance
    Barcodes can be captured faster, and there is no need to pause between scans or align scanner and barcode.
  • Built-in rechargeable battery
    Provides largest number of scans per charge - easily provides a full day of service in the highest usage profiles; replaceable battery ensures long lifecycle.
  • Compatible with 123Scan2 and Remote Scanner Management (RSM)
    Dramatically reduces management time and cost, from initial configuration to day-to-day management.
  • Withstands 100 consecutive drops to concrete
    Protects against downtime from breakage due to everyday drops.
  • Bluetooth 2.1
    Provides better security, better performance, better energy management and much easier pairing over the Bluetooth wireless connection.
Zebra LI4278 - barcode scanner
Barcode scanner - portable - Bluetooth 2.1 - decoded
Cash register white
Minimum Bar Width
3 mil
Scan Element Type
Linear imager
Scan Speed
547 scan / sec
Wireless
Wireless Connectivity
Bluetooth 2.1
7 cm x 18.6 cm x 9.8 cm
224 g
3-year warranty
Cash register white
Barcode
Interface Type
Bluetooth 2.1
Minimum Bar Width
3 mil
Scan Element Type
Linear imager
Light Source Wave Length
617 nm
Scan Mode
Single-pass
Scan Speed
547 scan / sec
Max Working Distance
6 m
Skew (Degrees)
65
Pitch (Degrees)
65
Print Contrast Signal (PCS)
15%
Decode Capability
EAN/JAN, Code 93, Matrix 2 of 5, Code 39, UCC/EAN-128, ISBT 128, NW-7, IATA, ISBN, GS1 DataBar, Bookland, Code 32, Code 39 Full ASCII, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Discrete 2 of 5, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, ITF, IATA 2 of 5, UPC-E1, GS1 DataBar-14, Code 39 Trioptic, GS1 DataBar Expanded, GS1 DataBar Limited
TTL Decoding
Decoded
Wireless
Triggered
Bluetooth 2.1
1 x USB
Cradle
1 x USB cable - external - 2.1 m
IEC 60601-1-2, ICES-003 Class B, FCC Part 15 B, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1
Software
Software Included
Drivers & Utilities
7 cm
18.6 cm
9.8 cm
224 g
Limited warranty - 3 years
50 °C
5 - 85% (non-condensing)
Drop Specification
1.8 m to concrete
Compatibility: PC
Brand: Zebra
