Zebra HC100 Wristband Printer
Quicklinx: 9255WS00 Mfr#: HC100-300E-1000
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Direct thermal
£397.11 ex VAT
£476.53 inc VAT
Zebra's complete and integrated wristband solution combines the small-footprint HC100 thermal printer with easy-to load cartridges containing Zebra's patent pending antimicrobial - Z-band direct wristbands. Its smart technology senses the wristband type and auto calibrates the settings for optimized print quality.
The design of the HC100 provides easy-to-use features that require minimal, if any, user interaction. There is minimal training required to use the HC100 or to load or switch the cartridge - it's a quick and simple task.
The HC100 printer is designed for wristband printing. Administrators can quickly process patient admissions without having to change the media in the printer. It also eliminates waste by printing only the required number of wristbands.
Zebra HC100 - label printer - monochrome - direct thermal
Printer Type
Label printer - direct thermal - monochrome
1.4 kg
Max Media Size
Roll (3.02 cm)
Print Speed
Up to 102 mm/sec - max speed - Roll (3.02 cm)
Max Resolution (B&W)
300 dpi
USB, serial
RAM Installed (Max)
16 MB SDRAM
Flash Memory Installed (Max)
8 MB
Language Simulation
ZPL, ZPL II, Extensible Mark-up Language (XML)
Barcodes
Code 93, Industrial 2 of 5, Code 39, Code 49, CODABLOCK, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Code 2 of 5, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Plessey
Media Type
Labels
AC 120/230 V
Microsoft Certification
Compatible with Windows 7
12.7 cm x 24.2 cm x 17.8 cm
Printer Type
Printer
Print Speed
Wired
USB, serial
300 dpi
Language Simulation
Fonts Included
16 x bitmapped , 1 x scalable
Barcodes
RAM
RAM Installed (Max)
16 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
8 MB
Media Handling
Media Type
Labels
Max Media Size
Roll (3.02 cm)
Media Sizes
Roll (3.02 cm), Roll (2.54 cm), Roll (1.91 cm)
Max Printing Length
558 mm
Media Feeders
1 x manual - 1 roll - Roll (3.02 cm)
1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B
TUV, VCCI, C-Tick, EN55024, EN55022 Class B, CB, FCC Part 15 B, IEC 60950-1, IEC 60601-1
Power adapter - external
AC 120/230 V
Frequency Required
50/60 Hz
Power Factor Correction
Software Included
Drivers & Utilities, ZebraDesigner, ZebraNet Utilities 7.0
5 °C
20 - 85% (non-condensing)
12.7 cm
24.2 cm
17.8 cm
1.4 kg
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 9255 040708
Condition: packaging damaged but item is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £145.82
Ref: 9255 040749
Condition: Customer return - item has been used but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £178.21
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (3.02 cm)
Brand: Zebra
Stock Status: Used Stock
Price Range Ex VAT: 300 - 500
