Zebra GX420t Thermal Transfer Desktop Printer
Quicklinx: 934XWS00 Mfr#: GX42-102420-000
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Direct thermal / thermal transfer
£457.93 ex VAT
£549.51 inc VAT
The direct thermal/thermal transfer GX420t has the easiest ribbon-loading system around. It produces 203-dpi print resolution at speeds up to 6 inches per second.
  • Always a perfect fit
    Zebra's G-Series compact desktop printers for print widths up to 4 inches deliver best-in-class speed and performance. The G-Series printers are reliable, durable, and flexible to fit almost any low- to mid-volume printing application and budget.
  • Fitting choices
    The premier GX model supports a variety of industries and applications with the widest range of features. Zebra's G-Series printer is a smart investment, and always a perfect fit.
Zebra GX420t - label printer - B/W - direct thermal / thermal transfer
Printer Type
Label printer - direct thermal / thermal transfer - B/W
2.1 kg
United Kingdom, Europe
Max Media Size
Roll (10.8cm)
Min Media Size (Custom)
19 mm x 9.7 mm
Max Media Size (Custom)
108 mm x 991 mm
Print Speed
Up to 152 mm/sec - B/W
Max Resolution (B&W)
203 dpi
USB, LAN, serial
RAM Installed (Max)
8 MB SDRAM
Flash Memory Installed (Max)
4 MB
Language Simulation
ZPL II, EPL2, EPL
Barcodes
Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Code 2 of 5, UPC, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Japanese Post, Plessey, MacroPDF417, EAN-14, Code 128B, Code 128C, German Post, MSI-3, Code 128A
Media Type
Labels, continuous forms, fanfold paper, tag stock
Print server - Ethernet, Fast Ethernet
Printer Features
Adjustable Media Sensor (AMS)
Microsoft Certification
Compatible with Windows 7
1-year warranty
19.4 cm x 25.4 cm x 19.1 cm
Printer Type
Label printer - direct thermal / thermal transfer - monochrome
Printer
Print Speed
Up to 152 mm/sec - B/W - 203 dpi
Built-in Devices
Status LCD
Wired
USB, LAN, serial
203 dpi
Language Simulation
ZPL II, EPL2, EPL
Fonts Included
1 x bitmapped , 1 x scalable
Barcodes
Printer Features
RAM
RAM Installed (Max)
8 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
4 MB
Media Handling
Media Type
Max Media Size
Roll (10.8cm)
19 mm x 9.7 mm
108 mm x 991 mm
Media Sizes
Roll (1.9 cm), Roll (10.8cm)
Max Printing Width
104 mm
Max Printing Length
991 mm
Media Thickness Range
0.08 mm - 0.2 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm, 12.7 mm
Media Feeders
1 x manual - 1 roll - Roll (10.8cm)
Print server
Network Controller Name
ZebraNet 10/100 Print Server
1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB , 1 x LAN - RJ-45
TUV, VCCI, C-Tick, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, CCC, FCC Part 15
Power supply
Software Included
Drivers & Utilities
Limited warranty - 1 year , Limited warranty - printhead - 6 months
5 °C
41 °C
10 - 90% (non-condensing)
19.4 cm
25.4 cm
19.1 cm
2.1 kg
Weight (Shipping)
4.1 kg
Ink (6)
934X Zebra RIBBON WAX 2300 110MM X 74M(Box of 12) In Stock £33.29
934X Zebra 1ROLL ZSLCT 2000D 102 X 64 MM 12 rolls In Stock £172.13
934X Zebra Z-Select 2000D 57x32mm In Stock £107.24
934X Zebra Z-Select 2000D Permanent Adhesive Labels In Stock £112.60
934X Zebra Ribbon Wax/Resin 110mm x 74m In Stock £50.22
934X Zebra Direct 1100 Perforated Matte Permanent Rubber Adhesive Paper - 16440 pcs. In Stock £114.43
Other bundles (2)
934X Zebra 3200 Premium Wax/Resin (12 Pack) - Black In Stock £29.37
934X Zebra Z-Perform 1000D - 880191-038D Economy direct thermal paper l In Stock £143.43
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (10.8cm)
Brand: Zebra
