The Zebra GK420d direct thermal printer offers the best value in a basic desktop printer, featuring a fast 5 inches per second print speed to meet your low to medium volume printing requirements. The GK420d has a sleek and compact design, boasts the smallest footprint in a 4-inch desktop printer, and supports a variety of applications and industries.
The GK420d comes standard with EPL and ZPL programming languages, and dual connectivity (USB, serial) for easy integration into existing systems. For additional flexibility, 10/100 internal Ethernet is also available. Well-suited to any industry, the reliable GK420d desktop printer is a smart investment that's always a perfect fit.
- Zebra GK Series GK420d - label printer - B/W - direct thermal
- Printer Type
- Label printer - direct thermal - B/W
- 1.4 kg
- Max Media Size
- Roll (10.8cm)
- Min Media Size (Custom)
- 19 mm x 9.7 mm
- Max Media Size (Custom)
- 108 mm x 991 mm
- Print Speed
- Up to 127 mm/sec - B/W - Roll (10.8cm)
- Max Resolution (B&W)
- 203 dpi
- Interface
- USB, LAN
- RAM Installed (Max)
- 8 MB SDRAM
- Flash Memory Installed (Max)
- 4 MB
- Language Simulation
- ZPL, ZPL II, EPL2
- Barcodes
- Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, CODABLOCK, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Code 2 of 5, UPC, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Japanese Post, MacroPDF417, EAN-14, Code 128B, Code 128C, German Post, MSI-3, Code 128A
- Media Type
- Continuous forms, fanfold paper, tag stock
- Networking
- Print server - Ethernet, Fast Ethernet
- Microsoft Certification
- Works with Windows Vista
- 17.1 cm x 20.9 cm x 15.2 cm
- Printer Type
- Label printer - direct thermal - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB, LAN
- 203 dpi
- ZPL, ZPL II, EPL2
- Barcodes
RAM
- 8 MB
- Technology / Form Factor
- SDRAM
Flash Memory
- Flash Memory
- 4 MB
Media Handling
- Media Type
- Max Media Size
- Roll (10.8cm)
- 19 mm x 9.7 mm
- 108 mm x 991 mm
- Media Sizes
- Roll (10.8cm)
- Max Printing Width
- 104 mm
- Max Printing Length
- 991 mm
- Media Thickness Range
- 0.08 mm - 0.2 mm
- Roll Maximum Outer Diameter
- 127 mm
- Roll Core Diameter
- 25.4 mm, 38 mm
- Media Feeders
- 1 x manual - 1 roll
- Networking
- Print server
- Network Controller Name
- ZebraNet 10/100 Print Server
- Data Link Protocol
- Connections
- 1 x LAN - RJ-45 , 1 x USB
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- TUV, VCCI, C-Tick, EN 61000-3-2, NOM, EN 61000-3-3, EN55024, EN55022 Class B, CCC, FCC Part 15
- Frequency Required
- 50/60 Hz
- Power Factor Correction
- 5 °C
- 41 °C
- 10 - 90% (non-condensing)
- 17.1 cm
- 20.9 cm
- 15.2 cm
- 1.4 kg
